Exercise & Fitness Logo
A
Anonymous Posted on Oct 19, 2013
Lifecycle r9. Where is the battery - Life Fitness Exercise & Fitness
Pioneer SX-R9 Stereo AM/FM Receiver. The select function CD, MD, TUNER, AUX is not working. How I can fix this?
Question edited for clarity and typo, remove .. dramatics ......
Duplicate question Deleted. Refresh page to see your question.
Pioneer SX-R9 Service Manual
ManualsLib https://www.manualslib.com > ... > Amplifier > SX-R9
View and Download Pioneer SX-R9 service manual online. Stereo Tuner amplifier. SX-R9 amplifier pdf manual download.
Or find a local audio technician.
1helpful
Need to find a manual for the Cubot R9 phone
hi John.
go tot his link and scroll down the page,and on the right you should see where to download the PDF file.
Cubot R9 Full phone specifications Manual24 co uk
or this one.
Manual User Guide Cubot R9 Download PDF
if none off the above work try this link.
manual for the Cubot R9 phone Google Search
1helpful
2answers
How do I can replace console batteries
Hi Abraham.
What I'm finding in the way of manuals isn't more specific than that the system uses 2 'D' size batteries, which should last about 800 hours. A review here
Lifecycle GX Review Spin Bike Reviews Indoors Fitness (about 2/3 way down the page) mentions that the batteries are in the console and easy to replace. I'd look for a battery door, likely secured with a small phillips head screw, and large enough to accommodate D Cells. It also mentions that there is a low-battery warning at the top of the console.
Hoping this narrows it down for you.
D
2answers
Explain the code error r9 and what is the solution
I don't have a definite solution however r9 is a heater problem it could be a short curuit between the heater and ground make sure the ground wire has not become loose or corroded
Screen wont work no display present
Most likely a dead battery,you could also check and make sure that that the sensor for the flywheel is in tact
You'll have to open up the battery assembly compartment on the user lower left side and replace your old batteries.
The LifeCycle GX power requirements are
• Battery: 2 D-Cell batteries
• Approximate Battery life: 800hrs
If this does not solve your issue or you need further assistance please do not hesitate to contact our Technical Support Team online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
7helpful
Where is battery located for LifeFitness' Lifecycle 9500HR
The Lifefitness Lifesyscle 9500HR battery location is at in the lower portion of the recumbent bike. This is a 1/2 to one hour task for most do it yourself'er.
In order to gain access to the battery compartment,you has to remove the pedals.
The center cover has to be remove.
Additional reference: Lifecycle Battery 0819-0012 Model Description Terminal Volts AH L W H Lbs Price 0819-0012 Fits Lifecycle Stairmaster series 4200, 4400 - Lifecycle Lifefitness CT8500, CT9100, 9500HR, 95Ci - Star Trac 5300/6300, 5400/6400, StarTrac 6100 Pro, 6200 Elite, ET4600 (0819-0012 replaces the 0819-1006) F2 6 2.5 4.48 1.81 2.75 2 $19.80
How can I determine which Lifecycle I own.. I purchased it second hand (X-Balley) and other then Lifecycle HR on its side I see nothing else discribing it. The battery is in need of replacement. I...
On the bottom the bike frame their should be s# plate. If you need to replace the battery you need to: first remove the foot pedals,then side panels.
they sold run about $20.00 to $27.00 plus S/H
I have a lifecycle model 9500HR, will not turn on.
Some of these units have the main battery ( 6v @ 2.5AH ) inside the bike frame and a 9v in the backside of the upper console
1helpful
I was told that my lifecycle 9500hr wasnt turning on because of the alternator. I replaced that and the display still wont turn on...any ideas of how to fix this????
You were probably steered wrong. I would expect the battery is the problem.
Use a voltmeter to check voltages.
If the battery is fully down, the alternator MAY have to have the field "flashed" to start generating.
In an automobile the current throu the alternator "idiot light" DOES THIS AUTOMATICALLY.but for your lifecycle I don't know how they do that unless the alternator uses permanent magnets.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
