Question about Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher
Fault with Hotpoint BCI45 Dishwasher
Hi I have an integrated slimline Hotpoint BCI45 dishwasher that was fitted by the previous homeowner. On starting a program and shuting the down the machine beeps and on opening the door the second green light from the left is flashing (regardless of which program you choose) and there is no water in the dishwasher. Hotpoint want to charge me £90 call out to look at it and won't tell me what's wrong on the phone. Any service manual would be much appreciated Cheers Gary
  • 57 Answers
This a generic problem with hotpoint dishwashers..
Water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Posted on May 23, 2008
SOURCE:
No hot water or drying cycle
Possible that the main controller unit is not switching on the heater for the hot wash and also the program for spin in the final cycle is absent. it all points to a faulty program controller but ONLY with a voltage check at the inputs and outputs during the cycle will confirm the fault.
Oct 20, 2011 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
No hot water in dishwasher cycle
If the program chosen contained the HOT WASH but there was not execution then the fault can be confirmed only if the voltage on the heaters and the hot line inlet be ,measured when the cycle advances to the next level. You will need to see if the program works in such a manner so as to switch on the heaters and also the hot valve to make it rinse the dishes with hot spray.
I have a hotpoint bc1450 no water coming into machine
Did the problem start directly after the washine machine was fixed ? I wonder if when the washing machine was moved back, the hose to the dishwasher has become trapped and kinked behind the washing machine. Or maybe the supply to the dishwasher is separate to the washing machine and has been turned off by mistake.
Dec 30, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint BCI 450 error message not in the manual
I had this on my machine.This indicate the drain pump is broken. Probably due to a leak from the heating element pipe joint above it. You can easily replace the drain pump yourself. Costs around £30. I got mine from Curry's partmaster in the UK.
Nov 04, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Flashing green light
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Mar 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Neff slimline dishwasher type S5946
hi there sounds like your wash pump has burnt out
Jan 11, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Hotpoint 18 in. BCI45 Slim-Line Built-in Dishwasher Logo
845 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
