SOURCE: Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
SOURCE: Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
SOURCE: I have a jacuzzi corner tub. The control panel
I would expect there is a Jacuzzi dealer in your town and I would guess he has parts. If you purchase parts locally, not only are you helping your neighbor but also, you will have the opportunity to pick his brain on tips to install.
Thanks for your interest in FixYa.com.
SOURCE: I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
