Make sure its fully charged, turn the headset off, press the call control button for 6 seconds, then try look for the headset on your phone. Passkey is 0000
first you must put the blue tooth device in pairing mode,most blue tooth device manufactures use the power button for this ,by holding the power button down for 6 to 10 seconds when turning the device on it usually puts it into discovery mode,a solid light might stay on ,then you have to enter a pairing or pin code.Now most manufactures of blue tooth devices use a 4 digit factory pin pairing code they are asw follows 0000,.1234,9999,or 1111 i hope this helps
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
