SOURCE: JVC Everio GZ-MC275AA
Video streaming is possible with DV camcorders thanks to the Firewire port (IEEE1394), which works very much like a digital video in/out connection. Basically, the camera just sends video, and if there's a computer attached, it receives the video and decides what to do with it on a computer.
USB doesn't work that way, normally. Most tapeless camcorders automatically set up the webcam as a storage device, which is a very distinct thing from a video streaming device. A storage device is just a disc of some kind... it will show up under some letter (eg, K:) in Windows, when you attach the camcorder.
Some USB camcorders allow for a "webcam" or "streaming" mode... I didn't find any specifics on your JVC, but I know some of the Panasonics support this. There are two ways. One is that, if you have the camera in record/standby mode, it may just go automatically into webcam mode when you attach USB.
The other way is that the camera will have something in the menus, like "Live mode" or "Webcam mode" that instructs it to configure USB for video streaming rather than storage-class attachement.
And of course, some of the tapeless camcorders have a Firewire port, just like a DV camcorder, which is there specifically to allow for streaming video, etc. You could use your camcorder as a web camera over Firewire, given the proper software... though you might find that's just as expensive as buying
a webcam.
And given the price of actual webcams, I would consider buying one
rather than adding wear and tear to my camcorders, just based on
price. This is the same reason I have a DV tape rewind device.. $20 device, $2000
camcorder... easy math.
SOURCE: camera JVC EVERIO GZ-MG33OHU
see if your camera has a USB. if it has then install the driver to your computer that camed with your camcorder. the drivers function is to allow the camcorder to use on your computer. insert the USB from your camcorder to your PC and now you can use it as a webcam. hope that helps!
CHARCOIS
SOURCE: JVC Everio GZ-360BU Camera Temperature is Too Low - Keep Power On??
I'm an English guy with the same problem... What you do is keep the power on for a long time, or you charge it up with the charger. Trust me. However, it is very rare for this to occur. There should be a message saying: "Temperature is too low, keep power on." There should be another message reading: "Turn off power and turn on again to check if camera is fully-functional. Thanks for giving me something to do while X-Plane downloads on my Mac OS X.
