I have a Pfaff creative 1471. When I turn it on the light flashes across like normal, but the computer display is blank. The normal little reset of the machine does not occur and the machine will not run. Any suggestions!?!?!?
I had pretty much the same problem. The changing the batteries. That took care of my issues.I had pretty much the same problem. The changing the batteries. That took care of my issues.
You can't post conmments that contain an email address.
Re: I have a Pfaff creative 1471. When I turn it on the...
The 1471 is getting on in years. It is not uncommon for the PC board to develop a fault. It can be replaced, however, cost is prohibitive unless you can find a repairer with a 'good' used board.
Good luck
It's not the foot, it is the 'Feed Dogs', the teeth in the base that pull the material UNDER the foot. The most likely reason is that you have lowered them too much, or set it to 'embroidery'.
You probably didn't disengage the sewing machine mechanism. Hold the hand wheel steady so that it will not move with one hand. Use your other hand to rotate the knob in the center of the hand wheel towards you. When the unit is properly disengaged, the motor can't move the needle bar. When done winding the bobbin, you need to hold the hand wheel and then turn the knob away from you. See page 9 of the manual for the Creative 1471. Pfaff has the manual on the product page: http://www.pfaff.com/en-US/Machines/creative-1471 . The current link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/creative1471-manual-EN.pdf .
Did you turn the knob inside the hand wheel backwards while holding the wheel itself? If that knob is in the correct position, did you hear it snap into place when you rotated the hand wheel towards yourself? Does the needle bar move up and down when you rotate the hand wheel?
If the machine still doesn't work, it may be that the belt is bad. This connects the shaft of the motor to the mechanism that runs the needle bar. You can find a parts list for the 1471 here: https://www.universalsewing.com/tek9.asp?pg=parts_pfaff . Scroll down to find the various 1471 diagrams. The belts are probably available at most Pfaff or other sewing machine dealers. This page, https://www.sewingpartsonline.com/pfaff-1471-sewing-machine-parts.aspx , is one source. You want the motor belt.
it show a part of the problem says a battery went flat,,was there any corrosion in the place you put the battery. if there was corrision it could have shorted something in the machine it's very posssible that something has gone wrong with the computer part of the machine
