Replacing a old TV with simple cable in VHF/UHF and it works fine. When same cable is connected to this Niko TV I cannot receive the signal and cannot set VHF/UHF input from TV or remote to find the signal. I tried from Menu to input source only options are: TV, PC, AV1 and Ypbpr? Can you help?
You must connect an Antenna to use the AutoTune. A set of rabit-ears is sufficient for most areas: RE: the Digital (Free) TV singals are using the old UHF/VHF frequencies - so any antenna designed for Broadcast TV should work. Connect your antenna to the ANT/Cable connection then re-run the Auto-Tune again.
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired. Thanks, lee
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna anda broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I'll be glad to assist you in locating the digital channels in the TV. Make sure that the Cable or Antenna Input is connected to the TV. The Cable and Antenna input can be connected to the VHF/UHF Input on the TV. The TV can search for the channels only if the VHF/UHF/CABLE input is connected to the TV. If you're connecting the Cable box or the Satellite Receiver to the Video or HDMI inputs on the TV, then it is not require to auto program the TV. Here, the auto program may be required in the cable box. To Auto Program the TV, select the Manual Channel Search option from the Menu option and then select the CABLE, AIR or Digital Add-On option depends on the connection. The Digital Add-On option adds any new digital channels that are found to the Channel Scan Database. This should resolve the issue. Please feel free to get back to us for further assistance. Thanks for contacting FixYa.
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
You can connect via a coax cable from the sat. box to VHF input of your TV and tune on ch 3 or 4 or connect via a RGB cable to component input of your TV or a regular Audio/Video composite cable will connect sat. receiver to your TV use yellow color for video and red&white for stereo Audio then choos the connected input on the menue and watch sat.
Try the $40 RCA DTV Tuner/Converter from Wal-Mart. Connect your existing VHF/UHF antenna (if you don't have one, Wal-Mart sells them too) to the antenna input on the back of the converter and the converter to the antenna input on the back of the TV. If it has only twin lead antenna inputs instead of the standard coaxial type, you'll need a simple twin-lead/coaxial connector, which is about $5. Tune to VHF channel 3 or 4 (set your converter switch correspondingly), turn on the conveter box and follow the onscreen instructions. If you see static, use the automatic or manual fine tune control until you see a clear picture of the menu screen.
