Garden Logo
William Power Posted on Oct 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Craftsman 2.6cu.in./42cc 2-cycle gasoline chain saw fuel line
Curtis Sewell
Level 3:
  • Craftsman Master 7,482 Answers
  • Posted on Oct 21, 2013
Curtis Sewell
Craftsman Master
Level 3:
Answers
7482
Questions
Helped
1943082
Points
24946
craftsman 2.6cu.in./42cc 2-cycle gasoline chain - 9b3a65ca-a109-437d-96df-2ef276eea6a5.gifHi William
Hope this is what your looking for...you did not give much description of what you needed
Bud
3 Related Answers
Anonymous
  • 211 Answers
  • Posted on Feb 12, 2009
SOURCE: craftsman 42cc chain saw
Hi
First change the plug with a new one with the same heat range.Clean the cilinder wings and the fan housing holes.Check the air and gas filters(clean them).Change the gas from gas tank.Dsassembly,check and clean the carb with compressed air.
Start the engine.
best regards savumihai71
Anonymous
  • 345 Answers
  • Posted on Apr 28, 2010
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Sep 10, 2011
SOURCE: need to know about fuel
Hi arisaleman...
This drawing is how most chainsaws,weedeaters,and most 2 cycle small engines fuel systems are run.
Please take time to rate me
1helpful
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Where to place fuel lines on a craftsman chainsaw model 358.352161?
http://www.ereplacementparts.com/craftsman-358352161-gas-chainsaw-parts-c-158286_172209_172289.html
The above link will take you to www.ereplacementparts.com
They sell all of the parts for your saw. There is also an exploded diagram. I am not sure if it will help you, but it may.
The other place I would try is YouTube. There are many videos on chainsaws.
I hope this helps and god luck with your saw.
1helpful
Fuel lines on craftsman chain saw
go to the website and see if you can download a manual
most saws have 2 lines fuel in and a return
the fuel in line is the one that goes in the tank and has a filter on it
hold you finger over the fuel line on carb and pull cord, the one that sucks is your fuel in, the one that blows air out is your return
9helpful
Need to know about fuel lines in craftsman chain saw 358-351160 how are they conected
Hi arisaleman...
Your manual that came with my 18" chain saw
The main problem with running 10% alcohol fuel is that it runs hotter than non alcohol fuel.What I have done for the last 15 years in my stihl chain saws is runs fuel oil mix slightly on the rich side. Stihl reccommends mix to be 50 to 1 and I use about 45 to 1 and they run great. One saw I've been using for 10 years and have had no problems. I also use a additive called sea foam, available at most auto parts stores. I use about 4 ounces per gallon. As far as your warranty goes If you cannot get alcohol free gas I don't see where you have much choice if you want to use your saw Hope this helps. Thanks
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
