Sony Ericsson Sony MT25i Xperia neo L Black Unlocked Quadband Android GSM Phone Logo
Faiyaz Alam Posted on Oct 19, 2013
My Xperia Neo L has a Wi-Fi issue where it doesn't connect to WiFi networks.I'm on stock ICS. It says "Connecting",it authenticates but then,either it shows that the connection is saved or disabled.Sometimes,when it does manage to connect,it keeps disconnecting itself and reconnecting again.Some help would be greatly appreciated.Thank you.
Nishant Dawadi
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 07, 2013
Nishant Dawadi
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
187
Points
Having same problem, did you solve it?
  • Nishant Dawadi
    Nishant Dawadi Dec 07, 2013
    having same problem, did you solve it?
Trouble Connecting Printer to Wi-Fi Network
I dont know if this has anything to do with it but I had an issue connecting my cam system to my wifi and it turned out it wont connect to 5g.
as soon as I logged on to the 4g wifi it, it was sorted
How do I When Brother Printer not connecting to WiFi?
When the Brother Printer not connecting to WiFi device or network, many reasons behind that below mention
Incorrect using the Wireless network
Using the Weak Wi-Fi signal
Brother printer away from Wi-Fi router
Incorrect using the Wi-Fi network setting
Firmware and Printer driver out of updated or not updated with the latest version
Printer driver corrupted condition
SSID or network incorrect using
If you will solve the above reason then your brother printer is easy to connect with a Wi-Fi network.
Now Get resolved the Brother Printer Won't connect to the Wi-Fi network?
Get below the troubleshooting steps to solve the Brother printer not connecting to the Wi-Fi issues.
Step1: Using the correct the Wireless network
Step2: Wi-Fi network must be strong
Step3: Printer placed near the Wi-Fi router or network
Step4: Printer WPS setting must be correct
Step5: Update the Firmware and driver problem
Step6: Use the latest version printer driver
Step7: Correct using the SSID network setting
Next also Read: How to fix the Brother Printer In Error State?
1helpful
3answers
Why is my brother printer not connecting to wifi
Assuming that you're using Windows 10, most printers seem to have problems with printing through wifi, especially if you've just made some major updates to Windows 10. Try these steps first - #1 You might have to reinstall the software and/or the driver for your computer. If it still doesn't work, try printing with windows default driver. If nothing works, then the best thing is to print using a USB cable.
Hello , wiped phone - when switching on phone says welcome then goes to select wi-fi network . when selecting wi-fi it shows authentication problem . what can i do
Authentication problem happens either when you have entered the wrong WiFi password, or possibly if your device is not compatible with the type of WiFi network you are connecting to.
Jan 08, 2019 • Cell Phones
My printer is not working wifi is ok
Printer not connecting to Wi-Fi issue can be caused when you have low network connection, outdated printer drivers and more. Follow the steps to fix Printer not connecting to Wi-Fi issue.
How to connecting wifi networks
Hello Pavan kalya naidu,
Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
now your wi-fi connect on your mobile phone .
Thanks,
Mar 18, 2016 • Cell Phones
Will not let me connect to wi-fi it is not my wi-fi servce. it just keeps saying authentication problem
It will say Authenticating problem unless you have the passkey to the other WiFi networks. So unless its your WiFi or an open network you won't be able to connect.But you can try rebooting your device.
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Wi-fi connection problem
There are 2 ways to approach your problem.
  1. Un-protect your wifi connection by removing the password. This is risky since other wifi gadgets can readily connect to your network.
  2. Configure your Samsung phone to connect to your password-protected wifi. Make sure that the wifi protocol of your phone matches that of your wifi router. Example, make sure to set WPA or WPA2 on both device.
3helpful
Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Top Sony Ericsson Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Sony Ericsson Camera Expert? Answer questions, earn points and help others
