Carrier 38CKC042 Air Conditioner Logo
P
Pete Nunez Posted on Jun 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on Cool mode and Fan is on auto. Out mode is not selected. Hold mode is not selected. When I go into programming mode, the desired temps show there just fine, but as soon as I go back to normal operating mode, zone 1 only displays dashes for the desired temps.
  • Pete Nunez
    Pete Nunez Oct 19, 2013
    I will also note that both zones are set with the exact same temps, auto fan, cool mode, etc. I am not trying for example to cool one room and heat another.
  • Thomas Woodburn
    Thomas Woodburn Jun 14, 2017
    Also, if these are the same, swap the two stats and see what happens
Thomas Woodburn
Level 3:
  • Carrier Master 2,638 Answers
  • Posted on Jun 14, 2017
Thomas Woodburn
Carrier Master
Level 3:
Answers
2638
Questions
Helped
1251711
Points
7008
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Comfort zone 7500 running constantly ?
read manual for setting up temp and time
Press the Set Time/Temp button until the HEAT icon is flashing. Press the up or down button until the desired heating temperature for that period is displayed. If that zone is going to be unoccupied press the Out button.-----------------https://www.northerntool.com/images/downloads/manuals/20390.pdf
Zone 1 has a red light by it and my up stairs won't cool down
That leaves a huge grey area. Help us help you. Are you looking at the zone panel? Is zone 1 upstairs? Does red mean powered when closed or opened? Are other zones cooling? Does zone 2 turn red AND when. Model numbers...
I have a older comfort zone thermostat. It is flashing program and says heat?? We are trying to put the ac on??
Change the system selector to cool. Press hold if applicable and then set desired set point.
2answers
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Hi installed brivis hx30 no common area x3 zone motors trying to install on net worker can only get zone a up any ideas
you will have to program all of the zones into the wall controller. to access the service parameters turn the controller to the off position then press clock. hold buttons 2 and 4 down for 5 sec then press the mode button it should display
1 01
or something like that u can scroll threw the parameters with buttons 1 and 2 and u adjust the values with the dial. for u it will need to be set to
1 15
1 17
1 18
1 20
2 21
1 23
3 24
this will then make it have all 3 zones so it will display zone A, B, C this is only for heating tho for cooling u will also need to program it in they are different numbers.
Hope this helped
-Chris
May 07, 2014 • Cell Phones
The Zone 1 (basement) and Zone 3 (second floor; no
On the zone damper motor, there should be a little lever allowing you to open the damper for emergency heat. Probably a bad zone motor or connection.
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
No heat in zone with Honeywell rth230B
It is not your thermostat, it is an airbound zone. The gurgly noise you heard was that water and air flowing through the radiator. The zone needs to be purged either at the boiler, or through vents on the radiator. Hope this helps
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
