Microsoft Windows XP Professional Logo
Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Some application software are not working.
My laptop's Windows XP Pro is having a problem with getting some application software working like Microsoft Office 2007, Windows Live Messenger and other Window Live Apps, Yahoo Messenger (their latest version), Adobe Reader 9, and others. The prompt message always says "This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem". I actually did that but still, those application software did not work. What may I do?
Sudeep Chatterjee
Level 3:
  • Master 3,267 Answers
  • Posted on Apr 25, 2009
Sudeep Chatterjee
Master
Level 3:
Answers
3267
Questions
10
Helped
1158614
Points
10260
You will need to install WinXP service pack 3 and some critical updates plus microsoft dot net distribution packages like" Microsoft.net 1,2 & 3". After installing them you will be able to install the various softwares you mentioned..........sodeep
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
2helpful
2answers
During install of Zebra Design Pro v2 on Winddows XP Proffesional V2002 SP 3 get "Exception EAccessViolation in module nbars.dll at 00099DD0. Access violation at address 008C9DD0 in module 'nbars.dll'....
I had the same exact problem, here is the fix:
1. Switch to Windows XP's Classic view in the Control Panel to turn off Themes. try using/installing the software
2. If this does not work, stop the Windows 'Themes' service. Then try the software again.
OS: Windows XP SP2 .NET 3.0 Product: Pinnacle PCTV HD Pro Stick Hardware: Dell Latitude E6400 - 4Gb Ram Error PMCLoader.exe ''Application has generated an exception that could not be handled'' I get this...
check the requirements of the your application make sure the requirements of that application is properly installed, if not reinstall the requirements and delete the registry keys for PMCloader.exe or Pinnacle and reinstall the pinnacle software...
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Not finding drivers for Windows XP Pro
Applicable drivers can be found here: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3740387
There are only keyboard drivers and the HP Software Update program. All other drivers ship as part of WinXP.
1helpful
How instile MS xp for notebook CP
If you have Vsta already loaded on your laptop and want to get rid of it, in favor of XP Pro, you must do a few things.
1 - determine if there are any files you need to keep, like documents (Word, etc.) or spreadsheets (Excel XLS, etc.) and like that.
2 - use a DVD-R or RW and write all the critical documents to the DVD so that you don't lose them in this process. Do a simple Copy from Windows Explorer.
3 - once all has been saved, the easiest way to accomplish what you want, is to boot the laptop using a legal Microsoft XP Pro CD or DVD, then follow the instructions to creating a bootable version of XP Pro on the lapop.
4 - you will need to decide if you want to have a dual-boot system or only an XP Pro system.
5 - if you want dual boot, follow the instructions; if XP Pro only, then follow those instructions. They should all reside on the XP Pro installation disk.
But remember that XP Pro is an older OS than Vista, so your installation media will only be able to get you so far. I would recommend following the instructions to creating an XP Pro bootable laptop only, and that means to then format the entire C drive, and then use the install media to create an XP Pro C Drive.
6 - go from there to an XP Pro laptop.
7 - as soon as the system is finished, and stable, rather than starting to install all the applications you want, like Office or other applcations, go to Microsoft's update site and update your XP Pro laptop to the newest versions of those things which will protect your system from outside problems. Update the protection applications from Microsoft first. Let the Update Site recommend, and choose from that list.
If you're going to install an anti-virus, like Norton AV, then start by installing the newest version of Norton AV or 360 or Internet Protection, etc. Then, go to the Symantec/Norton site, and update all those applications, too, especially the latest virus definitions or signatures.
Do it that way, to ensure your system is built slowly and with the most safety possible.
Be careful, and deliberate, and make sure you do not rush through this process, as it is extremely important to do it right, right from the start.
-a.
7helpful
3answers
Audio driver for Macbook pro
The drivers for XP are on the official OS X Leopard DVD. Install this when running XP and then run the Apple Drivers Set up on the disk.
Itunes for windows xp won't install on my windows xp pro pc.
Be sure you go the version for windows , not mac. also make sure you did not get the 64 bit windows verison. its easy to get the wrong one.
Good Luck
Sony vaio motion eye
You will need to get XP drivers for the product, they can be found here.
Wireless Network Driver
Dezzie.
This software will work with your Toshiba Laptop. This software was created by Toshiba. You need to install the Network Adapter. So go to Toshiba's website and update your network adapter drivers for win XP SP2.
Please let me know how this works.
Thank you
Cabletech
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
