I appreciate your inquiry, friend!
I understand that your Frigidaire range is displaying an "F68" and beeping. I would recommend performing a reset and you can do that by flipping the household circuit breaker off for roughly ten minutes, which should clear out any miscommunications within your range. If your range continues to display "F68" that could be a high voltage condition. This means that you may have an issue with the voltage coming into your range or your control panel. This is not a simple fix. I would highly suggest consulting with a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Thank you for your inquiry, Robert Klaum!
I see that your Frigidaire range is displaying an "F68" error code. I am unsure if another member has the same problem due to solar panels. Typically, an "F68" error code means that you have a high voltage condition. This could be an issue with the polarity, supply voltage, or EOC (Electronic Oven Control). I would recommend having a professional technician out to your home for a proper diagnosis to be completed. Best of luck! -Matt
