To slow down the stitching speed on your Husqvarna Viking 18 x8, you can try the following steps:
Check the machine's manual: First, consult the manual that came with your Husqvarna Viking 18 x8 machine. The manual should have instructions on how to adjust the stitching speed.
Adjust the stitch length: One way to slow down the stitching speed is to adjust the stitch length. A shorter stitch length will slow down the machine's stitching speed. Refer to your machine's manual for instructions on how to adjust the stitch length.
Change the foot pressure: Another way to slow down the stitching speed is to change the foot pressure. Reducing the foot pressure can help slow down the machine's stitching speed. Again, refer to your machine's manual for instructions on how to adjust the foot pressure.
Use a different presser foot: Some presser feet are designed for slower stitching speeds. You can try using a different presser foot to slow down the machine's stitching speed.
Use a speed control pedal: Some machines come with a speed control pedal that allows you to adjust the machine's stitching speed. If your machine has a speed control pedal, try using it to slow down the stitching speed.
If none of these steps help slow down the stitching speed on your Husqvarna Viking 18 x8, you may need to contact a professional technician for assistance.
I believe this machine can operate without the foot pedal attached. Disconnect the foot pedal and try using Start/Stop button. If same symptoms with pedal detached then likely problem is speed control module inside machine.
most sewing machines are controlled by a foot peddle the harder you press the faster it goes but if this one is electronic it should have another method of slowing it down
I'm thinking that the problem is in the foot control
take the foot control to a sewing machine repair shop and have it checked out
you say it appears aftermarket--probably is to replace a faulty OEM unit
According to the manual, there is no speed control on your machine. It is apparently built into the foot control unit. I suspect something is haywire with the foot controller but would suggest taking the machine and foot control unit to a sewing repair service.
