Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
There
Here
Dehumidifier
heatman101
drips water onto floor not in bucket, used to drip into bucket...did not change level location
