Computers & Internet Logo
G
Gwendolyn Armbruster Posted on Oct 19, 2013
Apple id password reset
I would like to take rhvac off the account
kumaransekar
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 40 Answers
  • Posted on Oct 20, 2013
kumaransekar
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
40
Questions
0
Helped
6924
Points
72
Ollow these steps to change your Apple ID password. If you can't remember your password, follow the steps for what to do if you forget your Apple ID password.
  1. Go to My Apple ID (appleid.apple.com).
  2. Click Manage your Apple ID and sign in.
  3. If you have two-step verification turned on, you will be asked to send a verification code to the trusted device associated with your Apple ID. If you are unable to receive messages at your trusted device, follow the guidelines for what to do if you can't sign in with two-step verification.
  4. Click "Password and Security".
  5. In the "Choose a new password" section, click Change Password.
  6. Enter your old password, then enter a new password and confirm the new password. Click Save when done.
The next time you use an Apple feature or service that uses Apple ID, you will be asked to sign in with your new Apple ID password.
How can I reset password for my Apple ID to get into ITunes?
Recover or Reset Forgotten Apple ID or Password on iPhone & iPad
This is all done on an iOS device and is often the simplest way to log back into an Apple account:
  1. Open the Settings app and scroll down and tap on "iCloud"
  2. Tap on the email address at the very top of the iCloud settings screen
  3. Tap on the blue text underneath the password entry that says "Forgot Apple ID or Password?" where you'll have two choices:
    • If you know your Apple ID and don't remember the password, type in your email address and click "Next" to start the reset process
    • If you don't know your Apple ID, tap on "Forgot your Apple ID?" and fill out your full name and email address to recover the Apple ID login (yes, you can then do the password reset after you have the Apple ID)
  4. Answer the security questions pertaining to that Apple ID, and follow the onscreen directions to complete the process
At this point you should be good to go, you can reset the password for the account and then login as usual.
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Reset my password I Apple ID
If the users face any kind of technical difficulty in accessing their Apple account or logging by Apple ID, so they can resolve the technical issues speedily by just contacting with our Apple ID Technical Support team. We are trustworthy and versatile technical support provider and rendering the excellent Apple ID Support to users for resolving their worrisome situations.
If you are annoyed to find people who will guide you guiley and you are unable to Fix it then first thing you supposed to do is to call our Apple Technical Support Number 1855-341-4016.
I cant get into my iphone i dont know my icloud account, what should i do?
Hello Diana,
First, don't freak out, we're human and this stuff happens. Apple provides multiple ways to recover a forgotten ID login or password, and you can start the recovery process either directly on an iPhone, iPad, or iPod touch, Mac, Windows PC, or just about anything with a web browser.
The different processes described below will work to recover a forgotten Apple ID (meaning the email address used to login), and/or reset a forgotten Apple ID password. This can be particularly helpful if you're setting up a new device for yourself or someone else, switching a device to a credit card-free ID, or changing the Apple ID associated with a device, and you can't remember the pertinent login information, or if your email changed at some point and you didn't update your Apple details to go along with it.
Before anything else, know that you can always Contact Apple for help with Apple ID account security if you want assistance through official channels to regain account access, which may be the best option for users who are overwhelmed or confused.
What if this doesn't work, or what if it doesn't find your Apple ID? You can try one of the next two options:
Find a Forgotten Apple ID by Email or Old Email Address
This is a more advanced trick to search multiple email addresses, which is incredibly helpful if you switched email accounts at some point in time and that's what has caused the login problem. This can be done with any web browser in iOS, OS X, or Windows:
1. Open the web browser of choice and go to this Apple iForgot website: https://iforgot.apple.com/appleid (creative name, eh?)
2. Enter the first and last name associated with the Apple ID, your current email address, and any and all prior email addresses to start the reset process
3. Answer the security questions associated with the user to complete the reset process
This will help to find the Apple ID, but if you can't recall the password to that ID then you'd need to go to the next step as well.
Reset an Apple ID Password from the Web
You can also start the password reset process from the official Apple ID website, this also can be done any device as long as you have a web browser:
1. Go to this My Apple ID site and under "Manage your Apple ID" choose the "Reset your password" option
2. Enter the email address associated with the account and answer the security questions as usual to complete the password reset process
Finally, if you're completely stuck, you're annoyed, confused, or none of the above has worked, you can contact Apple directly about your account here (Contact Apple for help with Apple ID account security ) or at you local Apple Store and in many situations they can help you to regain access again.
Login my itunes account
Nowadays, I believe that all users must actually have an AppleID to use iTunes, which is different than a password for iTunes. In other words, I used to sign into iTunes using my iTunes user name and password, but somewhere along the way, I was required to acquire an AppleID instead. An Apple ID is your user name for everything you do with Apple: Shop the iTunes Store, enable iCloud on all your devices, buy from the Apple Online Store, make a reservation at an Apple Retail Store, access the Apple Support website, and more.
I cannot tell by your question if you already have an AppleID and forgot the password for that account, or if you're trying to use your old iTunes account and forgot that password. If it's the latter, I don't think your old iTunes user name and password would work anyway. But I could be wrong.
If it's the former, here are the instructions for resetting your AppleID password (copied and pasted, obviously!):
If you forgot your Apple ID password Can't remember your Apple ID password? Try resetting the password.If you forget your Apple ID password or don't know it, choose from the following options to reset your password. After resetting your password, you'll be asked to sign in with your new password when you or your device accesses an Apple feature or service that uses Apple ID. If you know the answers to your security questions
  2. Select "Reset your password."
  3. Enter your Apple ID, then select Next.
  4. Select "Answer security questions" as your authentication method. Select Next.
  5. Select the birth date associated with your Apple ID, then select Next to begin answering your security questions.
  6. After answering your security questions, you'll be asked to enter and confirm your new password. Select Reset Password when done.
If these steps didn't help you to reset your password, contact Apple Support.
If you have access to the email addresses associated with your Apple ID
  4. Select "Email authentication" as your authentication method. Select Next.
  5. Apple will send a password-reset email to the primary address or verified rescue address associated with your Apple ID. Didn't receive the email?
  6. Open the message and select the link to reset your password.
  7. When the My Apple ID page opens, enter and confirm your new password, then select Reset Password.
If I missed the mark on your question, let me know, and I'll try to help some more.
2answers
Forgot apple id and password
Your Apple ID and password is the key to gaining access to the App Store, and Apple has a username and password locator tool to recover forgotten information.
Your Apple ID is usually the same as the primary email address attached to the account, and cannot be deleted once created.
As a security precaution, Apple resets your account password and allows you to create a new one rather than display the previous password.
Visit the Apple Forgot ID page, and click "Forgot Your Apple ID?" underneath the text field.
Enter your first and last name, current email address and up to three previous email addresses. Click "Next" to use the Apple ID locator to pull up all Apple accounts linked to the entered email addressees.
Click "Email authentication" and click "Next" to have the Apple ID sent to your email address. Open your email account, and open the message from Apple.
The message contains a link that redirects you to the password reset screen.
Enter the new password, and reenter it in the confirmation box.
Click "Reset Password" to submit the changes.
A confirmation email is sent to your email account with the name of your Apple ID and a confirmation of the new password.
Click "App Store" on your Macintosh's desktop dock and click "Store" on the application's menu. Click "Sign In" and enter your Apple ID and password.
Click "Sign In" to log into your account.
http://support.apple.com/kb/HE37
I forgot my password in Itunes how do I reset it?
Forgotten Password
If your iTunes Store account uses an Apple ID to sign in, you can reset your password by clicking here.
If your iTunes Store account uses an AOL screen name to sign in, you can reset your password by visiting AOL Help.
Change Password
You can change your Apple ID password through your iTunes Store account by following these instructions:
  1. Open iTunes.
  2. Click iTunes Store on the left hand side of the iTunes window, below Store.
  3. Choose Store >Sign In.
  4. Enter your Apple ID and password, then click the Sign In button.
  5. Choose Store > View My Account.
  6. Enter your account's password, then click the View Account button.
  7. On the Apple Account Information page, click the Edit Account Info button.
  8. Enter your new password twice.
  9. Click the Done button.
  10. Click the Done button at the bottom of the Apple Account Information page.
Note: If you think that someone else has access to your account, please change your account's password by following the steps above. To increase the security of your account, your password should be more than eight characters long and include both numbers and letters.
Grand Canyon Tech
Grand Canyon Tech
