SOURCE: Code for Comcast remote for Sony DAVHDX275
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
SOURCE: need a universal remote control code for sony dav-dz 100
1903 will work for most functions, but not the DVD player buttons.
SOURCE: Cannot find code for Comcast remote to operate DVD
hi im having the same issue, have u managed to find an answer? [email protected]
SOURCE: need code to program Comcast Universal Remote to our Sony DAV FR9
First you need a Comcast remote with the center button, OK/Select to be grey. Now program in code 1903 to aux. Works on my FR8 System, same basic as FR9. I was unable to get Comcast remote with red center, OK/Select, to work with any codes.
SOURCE: I need a Comcast remote control (silver with red
Hello
Will you please inform me about the exact model number of your Comcast Universal Remote Control? There are so many models of Comast Remotes have silver with Red Okey button. The model number be on its bodey [front of back] or at the inner side of the battery compartment or its protective lid. Without this, it will be very diffcult to anyone to guide you.
