Precor has standardized their error code messages across all their equipment so that each error will have the same meaning regardless of what model or equipment type the message appears
Here we list each error so that you can click through the specific error for additional details about the cause and action to correct the error
E000 Insufficient temperature rise of the fixing unit at power-on E001 Abnormality of the fixing unit E002 Insufficient temperature rise of the fixing unit E003 Low temperature of the fixing unit after standby E004 Error of the protection circuit in the fixing unit E006 Connection error of the fixing unit E008 Life expectancy of the fixing roller E010 Main motor error E012 Drum motor error E013 ITB waste toner full error E014 Fixing motor error E020 Drum/Developer-related error XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color E021 Developing rotary error E026 Toner empty error XX=01:Y XX=02:M XX=03:C XX=04:K E032 The counter of the NE controller fails to operate. E045 OHP sensor error E067 High voltage-related error E070 ITB HP detection error E100 BD error E110 Operation error of the laser scanner motor E202 CIS unit HP detection error E225 CIS light quantity error E227 Power supply error in the reader unit E243 Control panel unit error E248 Backup memory error E315 Abnormality of image data E351 Main controller PCB error E400 Feeder communication error E490 Model error E500 Finisher communication error E503 *** Finisher internal communication error E505 Finisher backup memory error E514 *** Stack delivery error / **** End assist motor error E519 **** Gear change motor error E530 *** Rear alignment error / **** Front alignment error E531 Staple error E532 Staple unit shift error E535 Swing error E537 *** Front alignment error / **** Rear alignment error E540 *** Stack tray up/down error / **** Upper tray up/down error E542 **** Lower tray up/down error E577 *** Paddle error E580 Stack tray up/down error E584 **** Shutter unit error E590 ***** Puncher motor error E591 ***** Puncher dust sensor error E592 ***** Puncher side registration sensor error E593 ***** Puncher shift motor error E5F0 **** Saddle paper positioning error E5F1 **** Saddle paper folder error E5F2 **** Saddle guide error E5F3 **** Saddle alignment error E5F4 **** Saddle rear side staple error E5F5 **** Saddle front side staple error E5F6 **** Saddle paper push-on error E5F8 **** Saddle connector error E5F9 **** Saddle switch error E601 Abnormality of image memory E602 Hard disk error E604 The image memory (SDRAM) is faulty/insufficient E609 * Abnormal low temperature of the hard disk E610 ** Failure in the hard disk cryptographic key E674 FAX board communication error E677 Abnormality of the external controller E710 IPC initialization error E711 IPC communication error E712 Communication error between the ADF and the reader E713 Communication error between the finisher and the printer E717 Communication error with the NE controller E719 Communication error with the coin vender/card reader E730 PDL error E731 UFR PCB error E732 Reader communication error E733 Printer communication error E740 Abnormality of the Ethernet board E743 DDI communication error E744 Language file/BootROM error E745 * Token ring board error E746 * Option board error E747 Main controller PCB error (Image processing ASIC or memory control/communication control ASIC) E748 ** Main controller PCB error E749 ** Restart in accordance with a change of the product configuration E803 Door close error E804 Controller fan error E805 Fan error
