I know you may be unwilling to do so, but I would check with your provider and make certain whether it is a matter of lack of capacity on your instrument or on the net which makes performance so poor for this data intensive application. It is obvious from the messages you are receiving that the constant updating needed for Google Maps leaves you without a data connection after the application starts.
yes
because I have a internet bolt on I have free internet access and the max data enabled.
Did you contact your carrier and make certain that your instrument is data enabled for as much throughput as is required to run Google Maps, a very data-intensive application, that some ISPs will shut down if the subscriber is overusing bandwidth?
