Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
My model Husqvarna CTH 171 does a great job as a tractor, hauling stone, wood etc. Recently it does less well at grass cutting. It cuts at the highest setting, but as soon as I lower the deck the engine cuts out. Why is this?
    Novelist:
  • 212 Answers
It sounds like when the unit is under more load it stalls out. It could be that bearings on mower need to be greased or replaced. Or it could be something internal. I would personally check compression with a compression tester. They are fairly cheap and easy to use. They simply thread in spark plug hole, you turn unit over and observe gauge. Probably a good tune up with valve setting checked/adjusted would be a good idea too.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Posted on Oct 19, 2013
SOURCE:
  • 6 Answers
SOURCE: Drive belt diagram
go to sears.com and put in model# for parts look up and they will have it or call 1-800-4my home to get owner manual
Posted on Apr 30, 2009
  • 27 Answers
SOURCE: My Husqvarna lawn tractor started smoking terrible
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
Posted on May 08, 2009
SOURCE: I have a Husqvarna 23hp 48
not sure but is battery being charged the right way have seen battery's put in and charged backwards
Posted on May 15, 2009
  • 376 Answers
SOURCE: i need a diagram to install a drive belt for this tractor
I need the model number under the seat to get you a diagram.
Posted on Jun 12, 2009
youcandoit2
  • 11 Answers
SOURCE: Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Posted on Jul 17, 2009
After 45 minutes of run time drops to half power
it is droping to half power to stop the motor from over heating check the water level and oil top them up.
Jun 27, 2015 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My husqvarna riding mower squeaks when i am cutting the grass what can i do to stop this
check all of you deck spindles and pulleys. sounds like some need replacing
Sep 13, 2014 | Husqvarna Garden
Hi Team. I too need a diagram to install the belt on my 2007 Husqvarna CTH2036 cutting tray. Can you help please. serial. 082207C001009. product. 960610217 01
The CTH machinesw have counter rotating blades, there should be a scimatic of the belt routing on the underside of one of the foot wells
Dec 03, 2012 | Husqvarna Garden
Looking for diagram of CTH 127 lawn tractor clutch, as was trying to fix and it fell apart
I am sorry we have no repair manuals here at fixya. Please contact the parts dept of a local dealer for a parts breakdown diagram.
Sep 02, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
CTH 171 Mower starts and runs fine but lacks power to climb even gentle slopes whether or not it is cutting.
The mover has great vibration as all mowers do. That is why the valves are recommended to be regapped at every 250 hours of running time. If not checked the engine will run although will be reduced in power going up a grade. Eventually it will not start so easily if not serviced soon
Jul 09, 2011 | Husqvarna Garden
I have a Husqvarna CTH 171. When i engage the blades they
http://weborder.husqvarna.com/order_static/doc/HO/HO2005/HO2005_5321938-34.pdf
This is the owners manual if you do not have one.
There is a brake on the pulley, make sure that is not hanging up.
Please let me know what you find.
Feb 08, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH20K46
How tall of grass?
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
95 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
