Hitachi 43UWX10B 43" Rear Projection Television Logo
Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My hatachi 43" projector tv is in 3d!!!
Tried to turn the tv on the other day and it wouldnt turn on,the red button just kept making a clicking noise.
after several attempts it finally turned on but the picture looks like its in 3d with a red shadow outlining all the pictures,words etc,can anyone help,im gutted!!!!
  • bonkers_furn Apr 25, 2009
    thankyou is it expensive?
electroman
Level 3:
Genius:
  • Hitachi Master 1,039 Answers
  • Posted on Apr 25, 2009
electroman
Hitachi Master
Level 3:
Genius:
Answers
1039
Questions
Helped
304827
Points
2353
Replace convergence ics.
  • electroman Apr 25, 2009
    About $50.00 if you can do it. About $300.00 to $400.00 if in home serv from a professional.
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
1helpful
I cannot turn on 3d mode on my lg projector pa70g cause it doesnot see this mode. And when i click 3d button on the remote it doesn't change the picture. Help me please!
you need to be connected to a 3d source when you try and switch and it must be playing 3d media before the projector would even try and im sure you know you need to be connected via hdmi for this to work, so grab a 3d dvd player and a 3d capable hdmi cable and a 3d dvd and then try it--Good Luck.
Light blinks red twice every 5 or so seconds on sony 24in 3d display. Anyone have or know the problem here?
same basic thing happened on my 50 in Hitachi plasma...I removed the back cover and found two capacitors on my power supply swelled...and two chips on one display board burned.Hatachi doesnt make the tv anymore and the parts were going to cost me almost what the tv did new...so...I sold it for parts on ebay...check all the boards for tell tale signs of damage...
6helpful
When I tried to switch on my projector Acer H5360 it makes some noise then it beeps 3 times, blue led light flash 2 times and then red is steady by returns... Its brand new.. Any idea? Pls help
Ordinarily my first thought would be that the lamp is needing replacement. But if it's brand new, the lamp should be OK. Can you open the lamp compartment to see if it was broken during transit, or perhaps it's not fully seated properly. If it's a broken lamp, then I would contact the dealer you purchased it from, or contact the manufacturer directly to have it replaced. Also, is the noise loud and unusual, or just the normal sound of a projector coming on? If it's very loud, it could be the fan motor. Check that the fan is blowing. If the fan is the problem, the projector will shut down to protect itself from overheating. That, too, should be covered under the waranty.
I have a Hatachi 43gx10b anf have a blue shadow that is warped, not straight, around the picture. I've tried the digital array but it won't converge the blue but the green and the red work. What can I...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dul
1helpful
2answers
Has Sound but no Picture and shuts down
I have the same tv and the same problem happened to me (Actualy twice). It turned out to be the color wheel motor. thats what the clicking noise is.
Screen projector un aligned
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
TV won't turn on.
I know exactly what the problem is. The protection door for the light is probably damaged by the heat of the lamp. The door has a little tab that indicates the cover is on. I had to fix mine by putting a screw; elongated the tab. Since then no problem... (I had the issue at least 3 or 4 times a day and I kept on re-tightening the door/cover)
Hope that helps
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
