IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
I believe this would mean that your battery either has a low charge or if you have the AC power cord plugged in, it could mean your battery is bad and won't take a charge
as far as I remember its the wireless working, if you press the button on the far right u can disable the wireless..this will turn off the flashing green light.
it all depends on the number of flashes , pause, repeat. Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are: 5 blinks 1 second apart No memory 6 blinks 1 second apart No graphics 7 blinks 1 second apart System board failure (detected prior to video) 8 blinks 1 second apart Invalid ROM
