I am trying to set up a wireless connection from my laptop to my HP Officejet Pro L7580 All in One printer. I have tried to follow instructions from the HP website, but it indicates that I must go through the printer display on the printer= Setup/Network- to turn on wireless connection. My printer does not have this as an option. How do I setup wireless connection with my HP Officejet Pro L7580 All In One Printer?
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
The 7680 model is the wireless connection model from HP. You would need a Print Server to make it work. You can get one on ebay, or at staples, office depot, you get the idea. If someone told you it had that capability I would at least have the conversation and maybe they can help you get the print server.
SOURCE: I have a laptop run
For this specific issue about installing the printer to a wireless connection. You need to install the software first as a usb connection. After the successful installation of the usb connection then you can add a device and it should work.
Step one: Gather the necessary hardware and information
Follow the procedure below before obtaining your wireless network:
You will need the following to set up the product on a wireless network:
Step two: Connect to an integrated wireless WLAN 802.11 network
Follow the procedure to connect the unit to the wireless infrastructure network:
SOURCE: HP OJP L7580 and VISTA no SCANNER available
You may want to try the full install before spending more time troubleshooting. It's a 300mb download (!), but it might be worth a try.
You don't say what software you're trying to use to scan, either; you may wish to try another one. If you want to experiment, you can download a free photo editing package that won't take over all your preferences for files -- check out portableapps.com and look for GIMP.
I've got an older HP printer, a PSC 1610, and it took me something like *seven* times installing it on Vista before it worked right. It turns out there's the regular uninstall, and then there's a super uninstall, and then there's a super duper uninstall, etc -- something like seven different uninstallation procedures, which is just insane.
HP's drivers and cruddy software convinced me to never by another one. It's a shame -- the company made some laser printers 15 years ago that are still working perfectly.
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
How do I make HP L7580 Wireless?
http://www.pdfsnatch.com/2013/04/hp-offi...
