Question about Precor 933 Premium Series Treadmill
Machine runs but quits after awhile but will start up after it sits for awhile
15.5hp johndeere riding mower just quit running
If it sits for awhile and then starts up then I would say you have an overheating issue. That is where I would start to trouble shoot. Could be a bad heat sensor...there are usually a couple of them.
Jun 05, 2016 | Garden
1992 Chevy Astro won't run, will start up great with starting fluid, or let it sit overnight.
You need to check the fuel pump pressure and I would change the fuel filter in the process. Sounds like you may have a bad fuel pump.
Sep 25, 2015 | Cars & Trucks
I have a 98 Deville (Northstar) that "cranks" quite a bit before starting, after it has been sitting for awhile. However, when it sits all night it starts right up, as well as when sitting for only a
There is a check valve inside the fuel pressure regulator that can leak off the necessary fuel pressure to start the engine quickly. Have it tested or just replace it.
Sep 14, 2017 | 1998 Cadillac DeVille
Precor 933 Premium Series Treadmill Logo
35 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
