I have eror d: allydataà00 ran.mgr.900
size 3370496
chars 512
so i can not rewrite my data company 49
I have an error D:\tally9\DATA\10005\tranmgr.900
size 19817472
position 19817472
chars 512(done0)
i can't rewrite my dat
I have eror 'E\tally.ERP9\data.'
size 512
Position:3211264
chars 512 (done 0)
I have eror C:\Users\Public\Tally.ERP9\Data\1016\TranMgr.900
size 3365376
Position:13573632
chars 512 (done 0)
?Error Code-0
hyjacker alert (Ding ding ding, OOHHHGAAAA) RELIC ALERT !!!!
Atul
error on unstated PC screen on on printers LCD? or? (sure some PC screen)
no PC told, and I guess you have some relic printer connected failing with TALLY name on the top of PRINTER?
NO PC told
no printer model told IDK,,,
no OS told windows what???, (user folder is windows sure)
running window VISTA or W7, that is what OP ran back in 2009, you too,, see why hyjacking fails.
your PC is not HIS PC dig.?
did you upgrade the OS from say W7 to 10,
now the TALLY printer drivers fail, well sure they do, if you failed to get new driver from TALLY.
is it a Tally T2245 Matrix Printer?????????????????????????
must we guess what you own and have and all things connected to a PC.
if you say (didn't) I have no printer , no talley and my used old PC has tally software loaded that I have zero need for this ever, then the answer is remove all TALLY software from the PC.
if you have a printer named TALLY, then post the model, I can not guess them.
tally (wiki it) went DEFUNCT in 2003 , 18 years dead.thne
In 2003, Tally merged with GENICOM to form TallyGenicom. In 2009, the TallyGenicom brand was acquired by Printronix.
So TALLY is now Printronix. only they can help you if they do at all.
wiki solved the riddle as did googling with care. lands hear
https://www.printronix.com/support/legac...
if you need drivers for an unstated TALLY that is your first stop
if no printer TALLY then clean the PC of all TALLY software. end story.
Either the drive D is corrupt, damage or not connected properly. Try restarting PC resetting the Device used for drive D:
Thanx
size 3365376
Position:13573632
chars 512 (done 0)
Error Code-0
so do you have 20 year old TALLY printer or not, (they are defunct ) YES/ NO???????????????????
if not then learn how to remove drivers old from windows.
if Control panel + program and features way FAILS to remove TALLY.?
then use this, even the free version one can work
safe it is from maker, and no where else.
https://www.revouninstaller.com/
that is not spam, it is a fact this product is SUPER good.
it removes all bits of any installed apps you do not want
at the end of the run.
click scan
then click select all
and click delete.
this cleans out program files, user appdata and registry of all parts of TALLY , if TALLY found.
it also has (amazing no?) a box called FORCED Uninstall, use this last if any of the above fail.
REVO is class act . and I have many years using it and love what it does.
I have the life time version that is not sold now, yah that good.
This can be seen on old PCs, 18 years old (2021-2003)
with XP then and some old tally printer used way way back then, (dark ages?)
and then you buy the PC, with this junk on it and no printer TALLY at all
or upgrade the OS and no such printer tally there.
nobody knows this story but you. (PC model, OS version, nor if TALLY is there or not)
or if PC was upgraded the OS.
I'd say off hand no VISTA, W7/8/10/11 drivers exist. now. for Tally is Defunct.
delete the tally folder, done.
the printer died 15 years ago so end it.
this post is to CURRENT HyJackers, 2021.
