Do not re-set you replace the developer. If you reset the copier will think it has new developer then will set voltages according when in fact the developer is old causing image issues and codes, replace the deveploer and run required procedures CLEAR THE COUNTER FIRST
You must press Utylity/Counter next open on screen admin setting. (Pass is 12345678) next network setting, IP setting and you can set IP address. If network (card, cable, switch or router) are OK you can print on your Develop. Driver you find on www.develop.de or http://www.konicaminolta.eu/en/business-solutions/support/download-center.html
Copy and paste this link (http://download6.konicaminolta.eu/develop/public/&&BDV&EN&sw&&&&&0&&&0&&0&&) or click here
in the product tab select ineo 163 , and select your operating system and language so that your result will be filtered and final output will be displayed after result came click link at end of the result. so that you can able to download driver for your ineo .
GOOD LUCK! if your probelm solved just don't forget to rate it
