The following info from
http://community.acer.com/t5/Tablets/Iconia-A500-frozen-at-Acer-logo-boot-screen/td-p/7171/page/28
might be helpful:
"How do I perform a Factory Data Reset if my Acer ICONIA TAB A500 does not boot?The
following steps will erase all of your personal information, all stored
contacts and any programs you have installed on your tablet.
1.Power off the tablet.
2.Press and hold the Volume up button, which is located closest to the touch screen lock switch.
3.With
the Volume up button held, press and hold the Power button for 3
seconds then release it. Continue holding the Volume up button.
4.Once the tablet vibrates, switch the touch screen lock switch on and off repeatedly while still holding the Volume up button.
5.Release
the Volume up button and stop switching the touch screen lock switch
once the "Erasing Userdata..." message appears in the upper left corner
of the screen.
6.Once the factory reset has been completed your
tablet will load to the Welcome screen. 7.Your Factory Data Reset has
completed now follow the onscreen steps to setup your tablet."
Good Luck!
SOURCE: I have an Acer Iconia
Acer Iconia Tab A500 has 16384 MB of Builtin memory. There is a plastic flap right next to the buttons, where you can insert a microSD
card.
You can add microSD, microSDHC Card of up to 64 GB MAX
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: put a password into my acer tablet A500 now i canrt remember it and cannot use the tablet
you need to go to any repair centre to flash the tablet.if you can do it then try using phoenix
SOURCE: how do I start acer iconia in safe mode
Hold the power button in for the count of ten, it should shut it down and cause it to ask you to boot up in safe mood, it may take a couple of tries but it will eventually go to a menu to ask for the boot mode....I recommend spyhunter4...I just removed that virus from a clients pc two days ago
