My Singer Quantum xl 1000 machine turns on, the screen lights but no icons appear. For a while the icons would come up when I turned the machine on and off but it has stopped doing that also.
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
SOURCE: I had my quantum xl 1000 sewing machine repaired.
Go to the internet, type find manual for Singer Quantum XL-1000, you should get a lot of links of which you can download.
SOURCE: My Singer Quantum XL 1000 is jammed and does not
Try to turn the hand wheel (on the right side of the machine) backwards ( if you are facing the right side of your machine, turn it clockwise) and try to remove the thread. Once its freed up, change the needle.
Hope that helps,
Chris
SOURCE: I need a throat plate
I would suggest contacting singer themselves in your country first off.
http://www.singerco.com/contact-us
They may run mail order spares sales.
Or there is www.sewingpartsonline.com, or www.sewingparts.co.uk who carry a wide range of spares.
SOURCE: Singer Quantum XL-100 Sewing machine can not see the stitch selection, but it lights up
the machine may need to be check to see if there is something wrong with the computer part of the machine
