SOURCE: kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
SOURCE: Air Dry Button just flashes
that is the fault code indicating the button is stuck. the touchpad must be replaced. the lock light indicated two or more buttons activated at same time
SOURCE: DISHWASHER LOCK
I too had the same problem,,and tried it again,,,and it worked for me,,i pushed the button next to the lock light it blinked and i kept holding in the dry button and the lock went off,,,,good luck
SOURCE: I cannot unlock the controls on the panel
Try turning the circuit breaker off for 30 minutes. Then turn back on and see. If it keeps locking you may need new control console. Hope this helps.
SOURCE: Dishwasher pops the circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Hello Le'Cinda Rhone - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another question, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. Then a beep will sound and LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
