If this is a Dell 093-962 try the following -
SOURCE: Dell All-in-one 924 error: "right cartridge is incorrect"
Hi ,
if you are getting the error msg 12203 , pperform the following steps,
remove both the cartridges from the printer and unplug the power adapter ( black box) from the back panel of the printer, clean the cartridges using a damp cloth .
initially put only the black cartridge and then turn on the system , it will give you the error msg right cartridge missing, you can ignore it and try copying a document .
remove the black cartridge and put the color one in, and then try printing.
during the printing with any of the cartridge inside the printer if it gives out the error msg 1203 then that cartridge has to be replaced...
SOURCE: Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
