If the drive you're referring to is the SCSI model, it doesn't have a "slave" option, but can be set to various SCSI ID's.
Click this link to get the skinny on all your jumper options:
http://support.dell.com/support/edocs/storage/6848p/Jumpers.htm
If you are using it on an older MAC it should work fine set to ID 1, if you want to use it on a PC check first if the PC even has a SCSI connector(rare for PC's of the same age as that drive as they primarily used IDE). The cables look almost identical but are in no way compatible
Hope this helps FixYa
Chris
Armor-IT
Is it a SATA or IDE hard disc?
