2002 Suzuki Vitara Logo
l
lloydie Posted on Oct 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plugged in a tester and the folowing code came out p0135 02 sensor heater circuit bank please advise on location and rectification
_-__-___-_
Level 3:
  • Suzuki Master 20,706 Answers
  • Posted on Oct 20, 2013
_-__-___-_
Suzuki Master
Level 3:
Answers
20706
Questions
Helped
6796871
Points
57965
First off ECU can never tell you what is bad, it can only tell you what tests failed.
135 test. failed.
Front sensor, left side of engine (engine not stated in post)
verbetum suz
P0135Heated OxygenSensor(HO2S)Heater Performance
a kinda dumb way to stated this Performance.
a better word would be HEATER dead,
or the heater no longer draws current is the better words.
this has 2 causes.
1: heater is dead, buy a new sensor they last 100k miles.
2: the wires to it fell off, stopping current flow, dead.
the latter issues, is a look and see it. it melted or broken wires.
http://www.fixkick.com/CEL/DTCs-1.pdf
you can read this page A80 in the FSM.
see this.?
http://www.acksfaq.com/96-FSM-v2-6E3-A-part2-pdf.htm
more that 4amps draw is a shorted O2sensor
less that .22amps is open sensor.
why? , well they all go open well before 11 years running.
or last worker, failed to put back the clamps to wires. allowing them to hit the exhaust and melt and short or open.
and this being bad wastes lots of fuel , so there is a return
on investment here.
2 Related Answers
digritz
david mcclellan
  • 530 Answers
  • Posted on Sep 07, 2009
SOURCE: PO135 Error Code
Bank one stands for the same side as the number 1 cylinder. Sensor 1 is the first sensor in the bank, (closest to the engine or upstream).
In most cases you will find it on the drivers side\left hand side of the engine and above the catalytic converter. Look for it on the lower portion of the exhaust manifold.
Anonymous
  • 678 Answers
  • Posted on May 21, 2010
SOURCE: where is the suzuki sx4 heater sensor located?
That is an error for a heater oxygen sensor (H02S). It's located on the exhaust pipe after the catalytic converter. If you have a 4 cylinder, there will only be one catalytic converter so it will be pretty easy to figure out which sensor to replace. If you have a 6 cylinder you will have to determine which bank is Bank 1 and which is Bank 2. If you can find a cylinder identifiction diagram bank one will be the side that cylinder # 1 is on. Whenever i have encountered a similar code it has always been a bad oxygen sensor. So, inspect the wiring to the sensor and if all checks out, replace the sensor.
Where is the o2 sensor bank sensor 2 located on a 2005 dodge durango 4.7 engine I get an error code of P0038
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2) It is located behind the catalytic converter, in the exhaust pipe . P0038 HO2S Heater Control Circuit High Bank 1 Sensor 2
2answers
Trouble code p0134, p0135 p0053 p0030
P0134 - O2 Sensor Circuit No Activity Detected Sensor 1 Bank 1
P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1
P0053 - O2 Heater Resistance Bank 1 Sensor 1
P0030 - O2 Heater Control Circuit Bank 1 Sensor 1
You need to replace the O2 Sensor Bank 1 Sensor 1
Carquest can help you get the correct part and help you locate it.
My 96 nissian maxima turns off when driving down the road i try to turn the key ,lights in dash on horn blows but will not startcould it be alternater ,or what how does the 02 sensor go by functioning ...
As of 1996,all cars sold in the US were required to have an OBD-II computer interface port.
You may want to go to Advance Auto Parts, AutoZone, or Pep Boys, and get a free read
of the code(s) that you computer may be posting to help with your diagnosis.
The code coming from your vehicle's computer may be one or more of:
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
P0300 - Random/Multiple Cylinder misfire detected
P0301 - Cylinder 1 misfire detected
P0302 - Cylinder 2 misfire detected
P0303 - Cylinder 3 misfire detected
P0304 - Cylinder 4 misfire detected
P0305 - Cylinder 5 misfire detected
P0306 - Cylinder 6 misfire detected
P0307 - Cylinder 7 misfire detected
P0308 - Cylinder 8 misfire detected
P0313 - Misfire detected with low fuel
Maximas with the VE30DE and VQ30DE engines use a distributorless ignition system that is controlled by the Engine Control Module (ECM). The ECM receives a signal from the crankshaft sensor (the CPS - Crankshaft Position Sensor), and processes the signal based on inputs
from other various engine sensors, including the Oxygen sensor.
(this is the role of the O2 sensor in ECM operation).
Then the ECM sends signals to each of the individual coils in the proper firing order.
This system is more efficient than a distributor, and has fewer moving parts. The high voltage coils are directly attached to each spark plug, allowing a higher energy spark within the cylinder. A high energy spark means a faster, more thorough burning of the air/fuel mixture, which produces more power and lower emissions.
SECONDARY SPARK TEST - works for all cars, including Maxima.
1. Remove the spark plug.
2. Install the spark plug to the ignition coil/coil pack, then attach the coil wiring.
3. Ground the plug at a good ground location on the engine.
4. Crank the engine and check for spark.
5. If spark occurs, the ignition system is functioning properly.
6. If no spark exists, test the ignition coil/coil pack, power transistor and related wiring.
HEI Ignition Spark test - works for all cars, including Maxima.
The next level test you may want to try is a HEI (high energy ignition) spark tester kit. Cost is
about $30 at most auto parts stores. Harbor Freight Tools sells a chinese equivalent for about $16.
Place the spark tester on each of the spark plugs, and watch as the little light in the tester will
light up each time the spark plug is fired by the computer. You can actually see weak or
intermittent sparking as the motor runs - you can tell by the relative strength of the light as
you compare the intensity and duration of the light across all 6 cylinders.
If your problem were the alternator (or its built-in voltage regulator), your battery would not be
getting a proper charge, and you
wouldn't be able to start the car after a drive, since the battery would have been drained during the
drive - normally, the alternator will both charge the battery and run all electrical
features of the car during a drive.
To test your alternator, place your DMM (digital multimeter) across the battery terminals while the
car is running - it should read 13.5VDC to 14.5VDC. With the car off, you can test your battery
voltage with the same DMM - it should read 12.65 VDC (for a fully charged battery).
Alternatively, you can take your car to Advance Auto Parts, AutoZone, or Pep Boys, and they'll
attach their "charging system tester" to your car and give your car a nice test for free.
I do this with my customers' cars just to get that nifty printout of the problem. Its nice
to show a vehicle owner somethng in black & white when I'm recommending a new charging
or ignition system component (some of which can be a bit pricey).
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
2helpful
3answers
2002 dodge caravan engine light on code showing p0135 .please advice.thanks.
  • O2 Sensor Heater Circuit Malfunction - Bank 1 - Sensor 1
  • Basically the ECM Electronic Control Unit has determined your O2 sensor is taking to long to begin reacting properly.
  • The causes could be
  1. O2 heater element resistance could be to high.
  2. An internal short or opening in the heater element.
  3. O2 heater circuit wiring with high resistance.
  4. Open or short to ground in the wiring harness.
  • The fixes are
  1. Check the harness and connector to the O2 sensor for shorts or ground.
  2. Replace that O2 sensor.
  • Bank 1 sensor 1 location for this vehicle is located on the exhaust manifold back by the firewall on top of the manifold..
  • Thank you for using FixYa
Regards, Tony
2helpful
2answers
Check engine sign appeared on my 2001 avalon , code error p1155, please advise
Appears it is an Oxygen sensor error, they are located in the exhaust system, in the v6, that code indicates the second bank (but unsure which bank that is) Ideally you need to take the car in for service, or at least inspect the Oxygen sensors, the code indicates that teh heater element has failed.
8helpful
2answers
2007 Chevy Tahoe check engine scan codes: P0030, P0053, PO135 ~ Please advise or help : ( thought that advanced auto would have been a bit more helpful than handing me a piece of paper with codes and...
There is a fault with the inbuilt heater in the oxygen sensor, before the catalytic converter, on the exhaust pipe the same side of the engine as cylinder 1. The oxygen sensor has four wires within the cable sheath to the top of it. Two of the wires will share the same color. These wires supply power to an internal heating element wire within the sensor. Follow the cable from the oxygen sensor to the connector, you can do a lot testing here. Check the resistance between the two 'same coloured ' wires. The resistance is low, somewhere between 1 and 10 ohms. If there is no continuity (infinite resistance) then this is the fault and the sensor needs to be replaced. The codes: P0030 the oxygen sensor heater relay is at fault P0053 Oxygen heater resistance error P0135 Sensor 1 bank 1 error You are looking at replacement. A further confirmation take the connection from sensor 1 bank 1 and swap it with the sensor 1 bank 2 on the other side of the engine. The codes should 'transfer' and show P0036; P0059 and P0141.
2helpful
2answers
Code error number p0135
P0134....O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135....O2 Sensor Heater Circuit (Bank 1 Sensor 1) heater in the O2 sensor has packed up first sensor before the cat
5helpful
Code po141 heater circut sensor/where do i find this sensor? where is bank 1
code is not for heater circuit,
code p0141=O2 Sensor Heater Circuit Bank 1 Sensor 2
that means its an oxygen sensor located in bank 1 which is the drivers side,sensor 2 means its the downstream sensor after the convertor
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Suzuki Expert? Answer questions, earn points and help others
