You can go to BIOS setup and check that CD drive is recognize there or not, If not then there must be some problem with CD Drive or connectivity of CD drive with computer, If it is showing there then you can follow this tutorial and change with the registry.
http://support.microsoft.com/kb/314060
SOURCE: I am trying to replace the hard drive in emachine
Go into BIOS Setup, and in Boot Order, change the first boot device to CDROM.
How?
To go into BIOS Setup you start tapping either the DELete key, or the F2 key, ->Right After you see the eMachines logo. If you miss this window of opportunity, simple press the CTRL, ALT, and DELete keys, At The ->Same Time.
This will restart your computer. Try again.
If you try the DELete key, and this wasn't the proper key, then use the above, restart your computer, and press the F2 key -> As Soon As You See the eMachines logo.
In the BIOS Setup main menu, look across the top for Boot Options. You cannot use your mouse to navigate around in BIOS Setup, you have to use your keyboard. Press the Right Arrow key to highlight Boot Options, then press the Enter key.
Your BIOS Setup may be different for this model. You may have to go down to Advanced BIOS Settings, in the main menu, and highlight it. Use the Down Arrow key to highlight Advanced BIOS Settings, then press the Enter key.
In the Advanced BIOS Settings sub-menu, look down the list for ->Boot Options. Use the Down Arrow key, and highlight it, then press the Enter key.
In the Boot Options sub-menu, you will see a list of boot devices. Floppy Disk drive, CDROM, HDD, (HarDDrive, or really -> HarDDisk), and perhaps a fourth one.
Use the Down Arrow key and highlight ->CDROM. Look down at the bottom of this menu, and see what the Navigation keys are. It won't state -> Navigation Guide, but that's what it is. You want the -> Change Value, keys.
It may be +/-, or Page Up/Page Down. (Plus + key, or Minus - key)
Using the Change Value key, move CDROM to the top of the list. (You have to hold the Shift key down in order to use the + key)
You may have to highlight the device on top of CDROM, and change value of it, in order to get CDROM to come to the top. Keep moving the boot devices, until CDROM is at the top of the list.
After CDROM is at the top, press the Enter key.
Now press the F10 key to save the changes you made. Now press the y key, and then the Enter key.
If you do not press the F10 key, and then the y key, it will be like you have done Nothing at all!
You haven't saved changes.
You may also have the words -> YES, and NO listed, instead of the Y key. (It's shown as a capital Y for clarity. Press the y key. Do Not hold the shift key down, and press the y key)
You can either use the appropriate side arrow key to highlight -> Yes, or just press the y key.
Now press the Enter key. Your computer will restart.
Your computer will now look in your CDROM drive for a boot disk. (It can be a CD drive, CD burner drive, or DVD drive, or burner)
IF, you do not have the Windows XP disk in your optical drive, or IF you did not get it in your optical drive before the computer booted up, don't sweat it.
Just make sure the disk is in the drive, and then press the CTRL, ALT, and DELete keys,
AT THE SAME TIME. Your computer will restart.
(Not 'shouting')
SOURCE: my emachines el1360 doesn't recognize cd/dvd
Try going to safe mode. Restart your computer and tap f8. Use the arrow key to highlight safe mode, and once you are inside safe mode. Try running the dvd or insert the sd card. If it runs well, then install RadarSync or any automatic PC updater then update the drivers. You can also manually update them by going to the website of your computer's manufacturer. Look for support and download.
Hi Barbara,
Is this SupeDrive a Solid State Drive by any chance?
Thanks everyone! I got it fixed which is great it has been this way for 6 months! I am now listening to music while I work again!
