Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Dimension 2400 Dell computer using Windows XP SP3. When I try to print I get the message that theDell 922 AIO printer can not communicate with the computer. Strangely, I can print with MS Office 2007 (trial) if I turn the printer on first and then use CtrlP. I get a message that the program has encountered a problem with ''dlbtjsw.exe''. If I click on ''Send a report'' and then click on ''Close'' when the second windows cmes up the printer procedes to print the page or if I click on ''Don't Send'' in the first window I get the same results, it prints the page Fred Blanck [email protected]
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Apr 25, 2009
Anonymous
Expert
Level 2:
Answers
90
Questions
0
Helped
32000
Points
220
Dear Fred,
try this link "http://tinyurl.com/5b2ttz"...
there u have to install the printer driver after uninstalling the printer from the computer.
once u install the printer again,you will not have any problem.
and for any hardware issues if you have any other problem you can mail it to me on [email protected]
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Updated to Windows Vista and now the Dell 922 AIO scanner won't work
    I assume the old computer was not Vista
    This site has the vista 32bit driver
    for Dell 922 AIO http://www.techspot.com/drivers/driver/file/information/8761/
    Dell 922 aio wontcommunicate with windows vista
    ********If u have installed the drivers from the old printer cd (used for windows xp ) ..on to ur vista os ,,,then we have some real problem and could take time but can be fixed *****
    If u have not installed any of printer drivers …then u should be able to print (cannot scan ) , jus as connect the usb cable to the pc and ur firewall or comp settings may be blocking the communication . *********replay to me and I will help further********
    I'm trying g to connect my Dell AIO 922 printer to
    You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
    My dell aio printer 922 will not print
    my dell aio printer well not print systen 32 spool driver is close how do i get it to come on
    Dell 922 printer will not print on the lines of lables
    My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
    Aio 922 power light constantly blinks on and off, will not turn on/off or communicate with computer.
    Try to unplug the power cable as well as the USB cable of your printer for few minutes. Then plug it back in, check the lights again.
    Dell 922 aio printer
    it's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
    Top Dell Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Norman Weimar
    Norman Weimar
    Ngoro
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
