You can try a hard reset, but that method will reset the phone to factory settings and will delete all data on the phone so if you proceed with this method backup all data if possible and remove the sim card and any external memory cards.
1. Remove the battery, wait for a few seconds, then reinsert the battery.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
SOURCE: I am having htc wildfire.
U CAN DOWNLOAD THE SOFTWARE FROM THE BELOW HTC SITE
http://www.htc.com/www/SupportDownload.aspx?p_id=316&cat=3&dl_id=1058
SOURCE: I am having htc wildfire. so i need pc suite for
hi,
Visit to the given link and download and install the "HTC Sync 3.0"...
http://www.htc.com/www/supportdownloadlist.aspx?p_id=316&act=sd&cat=all ...
hope this has helped you..
Please rate the answer.
Thanks...
SOURCE: i am back to my
It is not safe to enter free unlocking code to your HTC cell phone because it leads to data lost,So buy reliable unlock code by HTC WILDFIRE UNLOCK CODE provider with instructions.
THANKS ! ! !
SOURCE: Can you get free codes to unlock the htc wildfire
Dont trust free unlocking it wont unlock your mobile properly . Only trust best unlocking specialist , unlocking via codes is the best way for unlocking the mobile , follow the instructions here mobileunlockguide , then get the unlock code here mobileunlocksolutions , using unlock code specified in it proceed unlocking your mobile without vain ..
SOURCE: Htc inspire 4g stuck on lock screen and won't unlock
Please note that all data will be deleted from the HTC Inspire 4G as a result of this procedure. This process may or may not delete data stored on the microSD card. We recommend backing up all of your personal data before proceeding. First, try this: If that doesn't work, or if your phone is frozen: All data including third-party applications will be deleted from the HTC Inspire 4G. Once the wipe is complete, the phone will reboot to its factory fresh state.
