D
DAVID SHARPE BARBER Posted on Oct 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I NEED A YAMAHA HTR-3063 OWNERS MANUAL - Audio Players & Recorders
Electric Dime
Level 3:
Master:
  • Master 434 Answers
  • Posted on May 30, 2014
Electric Dime
Master
Level 3:
Master:
Answers
434
Questions
0
Helped
102008
Points
1138
Http://download.yamaha.com/search/product/?language=en&site=usa.yamaha.com&product_id=1098305
How to hook up eq to a Yamaha htr 3063
Hi Tyrone, I'm looking at the Yamaha HTR 3063 manual and it does not have the Tape-Monitor function, which would allow you to have the connections for an equalizer
This happens because of the variety of types of audio signals and they can not be processed for the insertion of an equalizer
Eventually, you could equalize a single signal, which you would connect to the EQ input and the EQ output, connect it to any of the RCA L-R audio inputs
Greetings Franco Dosil
Hola Tyrone, estoy viendo el manual del Yamaha HTR 3063 y no cuenta con la funci?n Tape-Monitor, la que te permitir?a tener las conexiones para un ecualizador
Esto sucede por la variedad de tipos de se?ales de audio y no se pueden procesar para la inserci?n de un ecualizador
Eventualmente, podr?as ecualizar una sola se?al, que la conectar?as en la entrada del EQ y la salida del EQ, la conectar?as alguna de las entradas de audio RCA L-R
Saludos Franco Dosil
https://usa.yamaha.com/files/download/other_assets/7/321147/HTR-3063_om_en1-1.pdf
https://data2.manualslib.com/pdf3/65/6430/642969-yamaha/htr3063.pdf?6a90cbe355c2bdc4e399d09c40d1a7ab&take=binary
How to fix a wobbly Volume knob on the Yamaha HTR-3063 AV Receiver?
it called a potenciometer find the number of it and replace just that part
My HTR 3063 is not producing any sound
The YPAO isn't on the 3063 model. only 4063 and up. If this is used and you can't get your money back, there is a firmware file here http://download.yamaha.com/search/product/?language=en&site=ca.yamaha.com&product_id=1436250 that can help get your receiver running correctly.
1helpful
No picture using my playstation 3 with my yamaha receiver htr 3063
you might have to reset the video output. hold down the power button for 5 seconds. It should beep and the iight will flash. wait a few seconds then turn it on.
Speakers wont work on the htr-3063....worked 10 minutes before on the old receiver
check to see what ohm your speakers are using. I know the 3063 supports both 6 and 8 ohm but it is defaulted at 8.
2answers
Where can i get firmware download for yamaha htr-3063
Hi al_sha,
Please be informed that Yamaha did not release firmware that can be downloaded by users, however they provided a step by step procedure on how to update the version of your unit. Please visit this link to have the Firmware update procedure for Yamaha HTR-3063.
Hope it helps.
Thank you for using FixYa.
2answers
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
 Grubhead
Grubhead
SmartAviator
SmartAviator
