Samsung HCM553W 55" Rear Projection Television Logo
Posted on Apr 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv big good morning! (samusung sp477w3hf1x) tv is the image of effort, because the colors appear purple and yellow! what will? already told me what could be the block of devergencia! this is the problem? I await a help, thanks!
Anonymous
Level 2:
Novelist:
  • Expert 159 Answers
  • Posted on Apr 25, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
159
Questions
0
Helped
63096
Points
407
If you have access to the color canyons then you can see one of the three is not lighting. (RED). So there is a process to know if the tube is totally inoperative or it can be saved. This process consist of trying to find the High voltage and second the video driver signal. A process difficult to do specially managing the high voltage who is really risky. be really careful to know to manage this area, a stroke can happen if you are not sure
The second area you mean divergence in reality is convergence. This area can be adjusted or repaired when three tubes can work, so go ahead with the diagnosis of the tube. or ask for a estimate in a workshop.
When taking pictures there is a color displacement of some sort. Leaves like bright purples and pinks shadowing images.It is worse in lighted areas, the more sunlight/bulb light the worse the coloring...
The term for an out-of-focus purple "ghost" image on a photograph is "Purple Fringing."
This is fairly common in Digital Photography.
In order to minimize instances of purple fringing you may incorporate the following:
Avoid shooting with big aperture (Small /f number) in high contrast compositions.
Avoid overexposing highlights (e.g. bright sky behind dark objects).
Shoot with a UV/Skylight Filter or a Circular Polarizing Filter. These protect the lens and also help to Get bluer skies and cut glare off reflective objects.
You could also use Post-processing to remove purple fringing by scaling the fringed color channel. This can be done in an image editor like Photoshop.
These suggestions will help in minimizing the instances of color displacement for you.
I will look forward to your feedback and positive rating.
2answers
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
2helpful
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Double color image (blue and Yellow)
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Color problem after warm up.
The probelm is caused by either a bad color wheel sensor, color wheel or formatter board. I have the new redesigned sensor assembly and color wheels that I can sell. It is best if you send me the projector for proper diagnosis.
6helpful
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
2answers
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
