Did you by chance check for DTC'S diagnostic trouble codes?
Instrument Cluster Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1255
Air Temperature External Sensor Circuit Open
Instrument cluster
Go To Pinpoint Test E .
B1257
Air Temperature External Sensor Circuit Short to Ground
Instrument cluster
B2097
Compass Module Failure
Instrument cluster
Go To Pinpoint Test B .
U2013
Compass Module - No Response
Instrument cluster
All Other DTCs
Instrument cluster
REFER to Section 419-10 .
The outside temp sensor is located behind your front grille. Try to look for a 2-wire small sensor. You will need to remove the grille to gain smooth access and to test it. Use multimeter to measure sensor resistance when disconnected. Depending on actual air temperatures, sensor should measure 1.27 kilohms when at 104degF, and 16.5kilohms when at -4degF. The rest of the normal values should be in between these kilohms and temperature ranges.
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Error Code: P0072
Description:
Outside Air Temperature Sensor - Low Input
Possible Cause:
- Wiring short to earth.
- Outside air temperature sensor faulty.
- Engine control module (ECM).
