Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
Posted on Apr 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i try to turn on my macbook nothing shows up on the screen and the white light on the bottom right turns on and stays on
  • 3 more comments
  • tcmckay25 Apr 26, 2009
    no there is no boot chime. when i push the on button the screen flashes white for a split second then goes black and the white light stays on.
  • Anonymous Apr 30, 2009
    exactly the same problem what should i do ??? thanks
  • Anonymous May 06, 2009
    my problem is the same but the white light flashes like it's in sleeping mode, but it won't do anything. I've changed the logicboard in it which didn't help and i'm going to be installing a new LCD screen and if that works i'll let you know. I do know however that my problem was caused due to lightning frying something and that's of course not covered under my warranty so I have to try and fix it on my own so it'll be cheaper.
  • Brian Wakefield May 11, 2009
    Mine does the same thing except it will make the little electric motor run over and over. I've found that by very slightly twisting the keyboard (power button corner to bottom left corner, and I mean like your going to fold it in half, but gently) it will them start. I'll let it boot all the way up and usually it's fine, but sometimes when I release the pressure it gets lines across the screen and locks up. Then all I can do is hold down the power button and try again. Once the thing gets good and warm there are no more problems (usually , anyway). Other times it will be working fine and just go blank and shut off, but the fan is still running. I know by having to twist it that it's a short somewhere but afraid to tear into it. I had to replace my hard drive about a year ago and this started a few months later. I did update to a bigger drive ( Hitachi?I think?)
      Sometimes the only way I can get it to come on is to actually turn thr computer upside down and power it up that way. HELP!!!!!!!!!!!!!!!!!!! Please??? Anyone????
  • Anonymous May 11, 2010
    does the boot chime sound?
Anonymous
Level 3:
  • Master 1,305 Answers
  • Posted on May 10, 2009
Anonymous
Master
Level 3:
Answers
1305
Questions
0
Helped
595970
Points
4327
Plug the power adapter in. Then hold down the startup button for 15 seconds. The light should go off and then after a few seconds. restart normally. The macbooks have a safety device that will lock up the drive if it detects sudden movements to protect the drive...
Let me know if you're back up and running. KEN
Damien Gole
Level 2:
  • Expert 221 Answers
  • Posted on Jul 29, 2009
Damien Gole
Expert
Level 2:
Answers
221
Questions
Helped
85927
Points
601
Please check your hard drive using your install DVD
Anonymous
Level 1:
  • Contributor 45 Answers
  • Posted on May 02, 2009
Anonymous
Contributor
Level 1:
Answers
45
Questions
0
Helped
31470
Points
89
Try holding down your power button until the unit turns completely off. Then try starting it back up.
I have a LG 47ln5400 and when I press the power button the tv screen flashes white really quickly then nothing shows up on the screen. The red status light turns on and stays a solid color. Then when I...
First you have to check if the back light of the panel works fine . if it's okay ..
Then probably you have a problem with the T-con.
It's a small board at the back bottom side of the panel . Connected to the main board by means of LVDS cable .
No data to macbook screen
For computers with Mac OS X 10.8 or later, if you have trouble getting your display to work with the computer, access the System Preferences menu and selection the Displays option. Then, press and hold the Option key. In the bottom right corner of the Displays window, you should see a Detect Displays button. Click that button to force the Mac OS to show all the displays, including the macbook's own display.
Otherwise, try resetting the PRAM:
by holding down the Command+Option+P+R keys on your keybord when you turn it on untill you hear the startup chime.
Happy New Year!
Kerry
1helpful
Our MacBook doesn't do anything but stay on a white screen that just shows that apple going around in circles in the middle of the screen.
You got the rainbow spinning wheel of death, which means take out the RAM chips and re-insert. Now try. Nothing? Replace the RAM chips with RAM chips you know are working. Now try-Nothing? Install disc one of the install disc Apple gives you and go into the system utilities and repair disc permissions and also click on repair disc after that. Now try-Nothing? Replace the hard drive and re-install the OS. Now try-Nothing? Your fu.kd my friend, which means you got a logic board problem.
I have an toshiba L305 laptop and when I turn it on I here the disc drive and the fans stays on the dvd rw woorks when I put a reinstall disc in it but the scree stays black from when I turn it on to...
You posted this problem in an Apple MacBook forum, which is why nobody has gotten back to you.
From the few symptoms you describe, I would suspect you have a damaged LCD panel or damaged inverter in your laptop.
The screen stays white and displays nothing
get a new one or call nintendo and tgell them
2answers
Macbook won't start!
that normally happend when the macbook do not find the software you can read this apple post http://support.apple.com/kb/TS1440
8helpful
3answers
Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: http://www.ifixit.com/Guide/Mac/ ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
dennismacfreak
4answers
Macbook wont turn on
My computer used to do the same thing, I found out it was my motherboard / logic board and a hardrive combination. end cost $1500..so i bought a new Laptop. Go and get those things tested.
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
