Sounds like a heat problem. You can take it in and see if you can get a larger heat sink with possible fan attached to it.
Terry
Testimonial: "thank u allen i try to buy a 3 colling fans bcuz my proccesor fan are always noise i think the heat i figure out later i let you know"
SOURCE: sound card driver problem
First you need to identify the sound driver, for that you need to download the application ASTRA 32 from (http://www.astra32.com/download.htm) run the appliction it auto detects your sound driver,
Then you can copy and past the name and version of your sound driver in google search and download it from the suitable website and run it ,
Best of luck
Regards'
Shib
SOURCE: my pc shuts down when
Plz Read System Requirement for Autocad 2010.
OR
Try removing Autocad.
OR
Formate your PC and install again Autocad.
SOURCE: This is the first time it's happened to me, but
u have memory problem restart ur pc and clean up disk, clean up firefox and ie , do deep system clean, clean up registry using reginout cleaner,use low graphics
Testimonial: "Well I did that an haven't had the problem since, so must've worked, thanks."
SOURCE: I have LG 155 mobile
By sundaram1931 on Aug 14, 2010
I have LG 155 mobile phone with external 2GB memory card. How do I transfer videos from my PC to the memory card and in what format? My videos in the PC are in 3gp video format.When I tried to transfer in this format the card says it is not supported. Please help me.
SOURCE: while opening a game hitman-blood
go to the microsoft support website, and type in msvcr71.dll into their search engine. They should have the file for download, as well tell you of any problems others have had relating to that .dll file
