DDR-400/PC-3200 I HAVE 845GVSR MOTHERBOARD WHICH SUPPORT 333MHZ/266MHZ/200 MHZ RAM. CAN I ATTACH 2 * 1 GB DDR-400/PC-3200 TO MY DESKTOP?
  • 31 Answers
If the memory supports those frequencies, in most cases it would work, now depending if the board is proprietary, like dell or some hp's, then you may run into compatibility issues. you can find this information from the manufactures website.
Posted on Oct 17, 2013
SOURCE:
Benimur
  • 6966 Answers
SOURCE: change 400mhz to 266mhz
Hi, Normally yes. It is the motherboard that will limit the memory speed. Shifting down from 400 to 266 should not be a problem. However, I have run across instances where the memory is cut in half (dunno why), but very rare. Good luck and kind regards.
Posted on Aug 26, 2007
iqbal_del
  • 655 Answers
SOURCE: Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Posted on Apr 01, 2008
The Machine
  • 788 Answers
SOURCE: Gigabyte GA-8IGX Motherboard memory upgrade
If you bay DDR 400 it will slow itself down to 266 automatically. I've seen a very few cases where it didn't work because of voltage differences but that is very rare and usually with really cheap OEM motherboards, your Gigabyte should be safe.
Posted on Aug 11, 2008
  • 31 Answers
SOURCE: Does D845GVSR supports DDR 400 MHz RAM?
unfortunetly your motherboard supports only 200, 266, and 333 MHZ
Posted on Nov 29, 2008
midwan
  • 55 Answers
SOURCE: I have this ASUS P4GE-MX
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Posted on Mar 13, 2011
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Mar 13, 2011 | ASUS P4GE-MX Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
RAM running slowly
hi there
this is very interting you are asking for fsb to adjest at 333mhz.
for this first you have to look your prosser fsb , *********** board fsb and your ram fsb.
fsb is a front side bus on which data ia is running at speed but for high speed you have to increase your fsb you are askin (ie:333mhz). itell you how?
example : your prosser fsb is 266mhz
your ram fsb is 400mhz as you told
*********** board fsb is 333mhz
now you system fsb is constant on 266 mhz because system on that fsb witch supporting by ram prosser and mobo( motherboard).
if you want to increase the fsb you have to buy mobo, ram,and prosser at same fsb.
Aug 15, 2009 | Dell Dimension 2400 PC Desktop
Memory ram
According to SiS® official document, SiS® 748 chipset has limitation DDR supports:
CPU at FSB 200MHz mode, it will NOT support DDR400
CPU at FSB 333MHz mode, it will NOT support DDR200
CPU at FSB 400MHz mode, it will NOT support DDR200/DDR266
Depends on chipset http://www.asrock.com/mb/overview.asp?Model=K7S8XE
Jul 22, 2009 | Computers & Internet
Nov 29, 2008 | Intel D845GVSR Motherboard
Regarding upgrading RAM
You'll need 184-pin ddr sdram memory
Supported speeds are 333, 266, and 200 mhz
Max memory for your motherboard is 2 gb, so the best you can get for your motherboard is:
2 x 1GB 333mhz 184-pin DDR SDRAM
May 21, 2008 | Intel D845GVSR Motherboard
    Suspend to RAM
  • CAUTION:
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Upgrade RAM
Max Supported RAM is 3 GB Memory Type DDR SDRAM Supported RAM Speeds 400 MHz · 266 MHz · 333 MHzNumber of Memory Slots 3 x 184 Pin DIMMs
yes, I beleive you can...
Mar 21, 2008 | ASUS A7N8X-X Motherboard
Open Questions:
Computers & Internet Logo
80 people viewed this question
Alun Cox
