Mtd Troy-Bilt Bronco OHV Tiller  Logo
Posted on Apr 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tiller starts then stalls
I start my tiller it runs about 10 to 20 seconds then stalls out and won't start. I wait 10 minutes it starts and does the same thing. Tiller was new last year and maybe has 5 hours of use.
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Apr 24, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801686
Points
33142
The air filter should be replaced. Also remove the old gas and put in new from the gas station. Finally, if you didn't change the spark plug from last seaon, do so as it is a small amount of cash for a lot of easy starts.
Why won't my brand new tiller stay running? Starts, runs a few seconds, then stalls.
sounds like its flooding
the float needs adjustment or seat needs cleaning or replace
Car stalle Security light on
Try your spare key.It could be that the primary key you have been using needs to be reprogrammed,which can be done by contacting a dealer.Turn the key to the "On" position in order to reset the pass lock system.Wait for fifteen minutes with the key in the "On" position.If the security light disappears, turn the key to the "Accessories" position and wait for a couple of seconds.Turn the key to the "Off" position and take it out from the lock cylinder. Wait a couple of seconds and turn the car on.--------------------------------------------------------------------------------------
Autel MaxiDAS DS708
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
I lost all power in a 2005 Trailblazer. Called GM and they said to kick the key forward and wait 10 min, and this would reset it. It did but now the radio A/C door locks and windows don't work. What...
Do it three times in a row.
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
Here is a link about the security problem
http://vatspasslockpasskeysecurityhelp.yolasite.com/
1helpful
How to rekey a pontiac sunfire 2004
Im assuming you are refering to the anti theft security key relearn process.
If that doesnt work, look into this link http://vatspasslockpasskeysecurityhelp.yolasite.com/
2helpful
Programing a key fob
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
