Hi Joanne
Here are a few things to check, you may have already checked some of these.
Electricity...Compressors will run best with full 115Vot 15AMP/Or 220V electrical supply from a circuit, over the shortest electrical cord as possible.
Air Leaks..Place your ear close to the compressor and listen for air leaking, if you hear air that is not normal and means you have to locate and repair whatever it is that is leaking.
Check the air unloader valve... The air unloader valve will blown out air when you turned off the compressor, that is normal.
But it should not have air leaking out of it all of the time. If so then it is faulty and in need of repair/replacement.
Valves...If either the intake or exaust valves fail, breaks, or fails to seat, then your compressor will run 24 hours a day and never build up to the correct pressure for shut-off.
Gaskets...Check to see if your gaskets have failed.
You could have a gasket failure between the pistons and you will never know it because it shows no external air leak.
If this situation happens then the air will only cycle between cylinders and never build up the correct air pressure.
One way to check the gasket is remove the air filter, then put your hand over the intake.
If correct then it will suck you hand against the intake.
If the valve or valves have failed then you will feel the air sucking in and blowing out.
Piston Rings and Cylinder...The piston rings could be stuck,broken, or worn and not allowing the correct pressure to build up in your tank.
A worn cylinder will also contribute to the problem of pressure build-up.
Pressure Switch...Check for air leaks at the pressure switch, it has a rubber diaphram that can fail and leak air out of the system.
Bud
SOURCE: coleman compressor no build up of pressure
your correct either the valves are worn or maybe just need cleaning as for the gaskets,idont know what part of the world your in but check out coleman on the internet or failing that ,i have maid these from gasket material suuplied from my local bearing supplier
Parts for coleman are available at www.mastertoolrepair.com your compressor is listed as L0502710. If however you like to tinker, you can make a pretty good reed valve out of aluminum can material or other (any ideas?). It is fairly easy to cut, does not last as long as factory stainless steel, but for short term, why not? Good Luck
SOURCE: I have a Husky model Y6010 air compressor.
First remove the valve using probably about a 1/2" wrench but make sure there is no pressure in the tank before you do so. check the cone and seal by loosening the valve by hand and check for debris. If there is no debris then the problem is either the pressure relief valve or weak pressure regulator but may also be a bad piston seal if it is a direct drive unit.
SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
SOURCE: I have 12 gal.1hp craftsman mod.921-166400 won,t
I would have to say if you are blowing oil out the crankcase that you have a piston or rings problem
