SOURCE: jbl gto 3501 amp
It's a mono amp. There's no bridging with this amp.
The two pairs of speaker terminals are connected together internally. The second set of terminals is for convenience.
SOURCE: Right side speakers don't work
if you are using RCAs as inputs to your amp.Swap the R to L @ RCAs to see if its comming in okay from radio.If both RCAs have audio then amp is bad ,If amp has any type of switches , move swithces to see if it comes back .Also if both RCAs inputs have audio .Move the RCAs when connected on amp to see if amp has bad connection in board to RCA jacks..If audio comes back on bad side when jack is moves .Then you have bad solder joints on board..If not then you must have bad outputs on amp..
SOURCE: JBL Sub Amp Wiring Please
it seems rather redundant to bridge a mono amp. Unless the instruction manual states otherwise, i would assume that one speaker output is identical to the other (ran in parallel, like an A or B speaker, not like Left or Right), and you would present the amp with a two ohm load by wiring one speaker to each output. Bridging it may or may not work, but, again, it just seems redundant.
SOURCE: Alpine mrp-m450 Amp won't stay on
Sounds to me like it might be the remote turn on because the first time i installed it, it did the same thing, and i found out that there is two blue wires coming out the stereo, one with a white stripe, i connected it to the blue wire, and it didnt work, then i connected it to the blue and white wire, and it worked. Well hope this solves your problem, goodluck.
