HP DesignJet Z2100 InkJet Photo Printer Logo
A
Anonymous Posted on Oct 16, 2013
Load valid paper for color calibration - HP DesignJet Z2100 InkJet Photo Printer
Mark Schmit
Level 3:
  • HP Master 1,915 Answers
  • Posted on Feb 08, 2016
Mark Schmit
HP Master
Level 3:
Answers
1915
Questions
0
Helped
753638
Points
7967
When you perform a color calibration on an HP designjet you must use a certain paper. HP bond plotter paper should be one of them. If you are not concerned about perfect color calibration you can lie to the printer and tell it you installed the paper it wants. If it cannot detect that this paper is not exactly what it is looking for it will perform the color calibration. Just keep in mind that it might not be exact or may fail.
1helpful
How to calibration kodak i2600?
To calibrate you need to use the Scan Validation Tool and a sheet of white A4 paper but you will need a daily key to allow this , Contact your local Kodak Alaris dealer they will usually give you a code
1helpful
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
1helpful
How do one correct print quality in hp color laser jet 2600n
Hi Good day!!
Follow this method hope it helps you!!
During the printing process, paper, toner and dust particles can accumulate inside the printer. Over time, this buildup can cause print-quality problems such as toner specks or smearing. This printer has a cleaning mode that can correct and prevent these types of problems.
This printer has two processes for generating cleaning pages: one is automatically generated and one is manually generated. When a new black print cartridge is installed, a cleaning page will be automatically generated prior to calibration.
Clean the fuser using HP Toolbox
NOTE: Use the following procedure to clean the fuser using the HP Toolbox. To clean the engine when the computer is running an operating system that does not support HP Toolbox, see the late-breaking Readme on the root of the CD-ROM, or visit http://www.hp.com/support/clj2600n .
1 Make sure that the printer is turned on and in the Ready state.
2 Open the HP Toolbox using one of the following methods.
On the Windows desktop, double-click the HP Toolbox icon.
* On the Windows Start menu, click Programs (All Programs in Windows XP), click HP , click HP Color LaserJet 2600n, and then click HP Color LaserJet 2600n Toolbox .
3 Click the Troubleshooting tab, and then Troubleshooting Tools .
4 Click the Print button next to step 1, "Click the "Print" button to print out the Cleaning Page."
5 Remove the Cleaning Page from the output bin, and load it printed side down in Tray 1.
6 Click the Clean button to complete the cleaning process. Press the GO button on the printer control panel. The Cleaning page will print, with a second page adhered to the first page. This is normal behavior during the cleaning process.
Cleaning spilled toner
Defective print cartridges can develop leaks. Also, after a paper jam has occurred, some toner might remain on the rollers and guides inside the printer. The pages that print immediately after the jam can pick up this toner.
CAUTION: When cleaning the printer, do not touch the ETB with a damp cloth or with fingers.
Cleaning the paper path
The device features a special cleaning mode to clean the paper path.
NOTE: If there is access to HP Toolbox, HP recommends cleaning the paper path by using HP Toolbox.
Clean the paper path
1. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Service, and then press (SELECT).
2. Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Cleaning Mode, and then press (SELECT).
A page feeds through the printer slowly. Discard the page when the process is completed.
3. Load plain letter or A4 paper when prompted.
4. Press (SELECT) again to confirm and begin the cleaning process.
Calibrating the printer
Calibrations are performed at regular intervals. For best print quality, a calibration can be performed from the control panel using the following steps:
NOTE: This will calibrate the color and clean the black electrostatic transfer belt (ETB).
1 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select System setup and then press (SELECT).
2 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Print quality and then press (SELECT). Calibrate color will display on the control panel.
Press (SELECT).
3 Use the (LEFT ARROW) or the (RIGHT ARROW) button to select Calibrate now and then press (SELECT).
4 Press (SELECT) to start the calibration.
Other options for print quality defects that still persist
1helpful
Black cartridge is new,magenta is new blue is halfway and yellow is halfway but the hp color laser jet 2600n prints lighter and black prints as it is finished
Hi Good day!!
Press (SELECT).
1helpful
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
1helpful
Just installed new printhead and new black and colored ink cartridges. I do not have a calibration calibration sheet any longer. This is for Kodak easyshare 5300 printer.RAU
When you install new printhead in the printer, you will get a message" New printhead detected ,load papers in paper tray and press start. If u do not get this message,that means you have not installed printhead properly. Visit www.kodak.com/go/printheadsupport and click on 3 rd link installing or replacing a printhead to see how to install printhead correctly
Color isn't true
You'll need to calibrate your screen and your printer - calibration is required for every set of paper and ink you use. It's quite a science and an art. I suggest you google "colour space" "printer calibration" "gamut" etc and read up on it. Alternatively you could spend a few hundred quid on a printer calibration tool, either the Colormunki or the Spyder print studio.
It still won't match perfectly, as the way color is created on a screen differs hugely for to how it is produced on paper.
Start with a properly calibrated screen first though (my money is on the Spyder elite screen calibrator and spyder print calibrator)
I'm a pro photographer and I print my own photos - full system calibration is the only way. www.yourhandinmine.co.uk
Steve Causon
1helpful
4answers
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
2answers
Hp photosmart c7280 won't work states calibration off
Solution
If the color or photo paper is loaded in the input tray when the printer aligns, the calibration might fail.
Follow these steps to resolve the issue.
Load unused plain white letter or A4 paper into the input tray.
Press the OK button on the control panel.
Cause
An incorrect type of paper is loaded in the input tray
My hp 1610 all in one
Is the color missing on the calibration page? Maybe some color or cartridge is empty and the printer can not calibrate... Without calibration no work !!!
k24674
Grand Canyon Tech
Grand Canyon Tech
