Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
O
Oscar M Posted on Oct 16, 2013
Machine stops and displays solid red light after dispensing 1 shot. Turned machine off and back on, and able to dispense another shot, then stops again ???
5 Related Answers
Anonymous
  • Posted on Nov 15, 2007
SOURCE: Saeco Incanto Flashing Red Bean Light
I found a machine in my dentist's office with this exact same problem. I'm not familiar with the model, so I downloaded a manual for the closest model I could find online (the Sirius), and it offered no help -- but in 8 languages!
I ended up just pulling the drip tray, pulling the box where the grounds end up, and re-inserting the assembly (all while the machine was on.) When I buttoned it up again, it worked.
Hope this helps (although I can see how it might not...)
Anonymous
  • Posted on Jul 20, 2008
SOURCE: Saeco Caffe Charisma lights do not stop flashing
I had the this same issue and made a post to this thread, in that post I had this solution to my conditions.
The combination of actions that seem to work was turning the Saeco on while the steam valve was already open and selecting hot water once the Saeco was powered on. The prime light went out, I closed the steam valve
Anonymous
  • Posted on Apr 11, 2009
SOURCE: red water light is flashing
I read through many old posts and found the answer I was looking for. I turned the hot water nozzle on for 45 seconds and the problem went away.
Anonymous
  • Posted on Jul 10, 2009
SOURCE: Limited water output (saeco vienna superautomatica model year 04)
I had the same issue with the same machine for about the same amount of time. I bought a new pump and a mainenance kit. I found tons of calcium build up inside the boiler, and the bolts to the boiler were rusted to the point where they broke off. The old pump was very noisey and failing to pump water through the clogged boiler. After cleaning out the boiler, replacing the o-rings on everything, and a new pump, the machine is like new.
Anonymous
  • Posted on Aug 23, 2009
SOURCE: new Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
I have descaled my machine Delonghi Nespresso Lattissima touch but my 2 lights on the right hand side of the machine will not stop flashing so no milk comes out. how do i fix?
Not clear if loss of steam to milk dispenser or milk dispenser itself clogged.
Try descaling again. Try running the vinegar through tbe machine about 1/2. Then stop tbe machine and allow additional time for the vinegar to work.
Also run a clean cycle using vinegar.
Also try disassembling the milk dispenser and clean manually.
2 red lights on CPU board
I will assume that you have the first on/off switch turned on and the one for the element is not turned on. The machine is saying it is not ready to dispense hot water or steam.
GE Refrigerator Ice and Water dispenser stopped working after power outage
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Hello! my 102534 gaggia esppresso machine has liquid/espresso dispensing after the 'espresso dispenser' has been turned off. if i turn the entire unit off, it does eventually stop. i've have...
HI JULIE,....MAKE SURE YOU ARE NOT FILLING THE WATER DISPENSER PAST IT'S OVER-FLOW...THERE IS A HOLE TOWARDS THE TOP...YOU DO NOT WANT TO FILL PAST.
HOPE THIS HELPS!
My indesit idl has stopped working. The red light comes on but none of the green setting lights come on - any ideas
Led 1= Prewash / 3hr
Led 2= Wash / 6hr
Led 3= Rinses / 9 hr
Led 4= Drying / 12hr
LED. illuminated
1 = Overflow ( water in base )
tip machine back. does water come out? if so you have a leak, possibly from bottom spray arm nut or loose salt pot. see if they are loose. if not, remove the base, put dishwasher on a block of wood, shine torch underneath to see where the leak is.
1+2 = Pump timeout, or Software recognition error ( timer not programmed, wrong keypad)
1+3 = Circulation pump not working
2+3 = Not filling
2+4 = Heating circuit not working
2 = Solenoid valve 'broken'
3 = Thermistor (NTC) cicuit not working
4 = Temp not reached whilst heating ( poss NTC detached from casing).
remove door panel. ntc is attatched to the rear of dispenser, a little white thing with 2 black wires on it. refit to the clip on the dispenser.
It is usually necessary to 'reset' the machine after a fault code has been displayed. Resetting.
Switch dishwasher OFF, rotate the selector switch to STOP/CHANGE and switch on, after a few seconds the LEDS will go out enabling a new programme to be selected
Aug 20, 2011 • Dishwashers
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
2helpful
4answers
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
3helpful
Red water light is flashing
Machine does not stop after dispensing two shots of espresso
That kind of machine is pretty well engineered!Very solid and work on a basic deal.The problem could be just the simple on/off button.
The pump is controlled by the button and if the button don`t stop the machine still understanding you need more until you close the circuit.Sometimes coukld be also a loose wire.
In some way you are lucky because that machine have not electronic board so...less part.....less problem
Don`t forget to rate your experiene
Fabio
4helpful
2answers
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
