Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Paper feed jam on bizhub c25 - Konica Minolta bizhub C250 All-In-One Laser Printer
3 Suggested Answers
SOURCE:
  • 1316 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
firecontrol7
  • 6850 Answers
SOURCE: konica 7025 paper jam
Does this happen when he orginals go thur the document feeder? How does the copy look if the orginal is placed on the glass. Vertical feed problem mite be dirty rollers or dirty clutch,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Aug 17, 2009
Funny noise indicating that there is a paper jam while there is nothing what to do to clear that noise.
instead of paper jam might had a miss feed which is the paper cant be picked up. which draw all draws? broken gear (s)
Dec 14, 2015 | Konica Minolta Bizhub C652 Color Copier,...
My c525 i restting very often
Why are you resetting it what is it doing showing a code ? powering off? Jamming? please explain
Sep 03, 2014 | Konica Minolta New Bizhub C25 Color Laser...
C0315
There is a fan in that draw that helps feed the paper by blowing on it check that fan burned out, dirty, jammed????????
Feb 28, 2014 | Konica Minolta Bizhub C 6500 Copier
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
Bizhub pro 1050: le code error SC32-32
Draw #2 Paper feed assist fan (located in the paper guide rear is bad jammed with paper dust or burned out /Rr2 (FM23)
Nov 02, 2013 | Konica Minolta bizhub Pro 1050 Corona Wire...
Bizhub C25 scan to email
Is the file that you are scanning to a shared file, required
Apr 25, 2013 | Konica Minolta Bizhub C35/c35p/c25 Magenta...
Paper jam on display but there's no paper jam
Then the roller are dirty or need to be replaced because they cant grab the paper so the machine is miss feeding jam is when the paper hit something or stop electrically move to different draw or the by pass
Jul 25, 2012 | Minolta bizhub 200 All-In-One Printer
Konica Minolta bizhub 250 jammed but no paper
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Paper jams when folding 8 1/2 X 11 ivory paper; less often with white. Tech says it's a paper issue - so whose colored paper (brand) will work - or is it a design flaw?
Is this paper the same weight/thickness as the white paper?
Are you specifying the settings properly as far as the weight and type?
It sounds like the sensors are detecting a double feed(?)
Try different settings for the tray, and even try a different brand of stock to verify.
Apr 29, 2009 | Konica Minolta bizhub C450P Laser Printer
Frequent paper jam
Where is it jamming?
In the feed tray, along the paper path, in the imaging unit or at the exit/finsiher?
The first thing is to be 100% SURE you are entering the paper settings correctly.
Jun 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
231 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
