Question about Canon PowerShot A720 IS Digital Camera
Wont take pictures with flash
I have a Canon digital camera...occasionally my camera will stop taking pictures, I can take them manually or with the flash shut off. when I press the button, the flash symbol blinks on the display and the red light on the front comes on. The camera makes a noise but wont take a picture. Its a powershot A720 I think...
  • kayla_h4 Apr 27, 2009
    I have tried changing the battery so many times, doesn't work...it's so random...sometimes the flash is fine...sometimes not..ugh.
  • Anonymous May 13, 2009
    This just started happening recently. Whenever I try to take pictures with flash, the flash symbol flashes (and the red light goes on), but doesn't actually take a picture. Pictures take fine w/o the flash, but they are blurry (as usual). Fresh batteries don't fix this problem. Also, I have tried taking out the batteries, and turning off the camera and "resetting" it which only works for about 2 or 3 pictures before it is back to not working again. I have a Canon A720 IS.
    New Friend:
The problem is in the battery holder of the CR1220 battery.
-Take out the CR1220 battery (the little round one).
-When you replace it, put a bit of aluminum foil against the back, between the battery and the plastic holder, to make it a nice tight fit. One layer won't do it, but don't put in half the roll.
-Put it back in. Done
Using a fresh battery & clean it all with alcohol = good idea as well. Worked for me.
Wich
Posted on Jan 14, 2011
  • jackpresence May 27, 2011
    Don't be frustrated. I had the same problem during a recent holiday. I had to use the camera in the P-mode during holiday; the auto-mode dosn't function. Now at home after reading this comment I lift the contact strips in the closing of the battery compartment a little, and the camera tokeagain a picture in the auto-mode with flash. So this proves it is due to bad contacts with the batteries, as Wichstem mentionned.
    New Friend:
I had the same problem - my Power Shot A720 IS did not take pictures with flash. I thought that the problem was CR 1220 battery (this small round one) and change it for new one. But it did not work.
I found solution on polish canon forum (Canon-board.info) - I switched off the camera, removed the screws, took out the cover and moved gently the white/green tape near the flash. Then switch on the camera and...
It does work!:D
Posted on Dec 31, 2012
  • John Rose Feb 07, 2013
    Thanks for this tip. I just moved the white/green tape, and the flash works again.
    New Friend:
  • 20 Answers
I was skeptical about this fix at first, but as per Mary's solution, I removed the 6 screws to the housing, eased the back and front plastic off, removed the plastic flash assembly shield screw.There, above the screen, you'll find a green and white ribbon cable.I carefully pushed them back into their seats and voila! The flash that used to only give me a blinking lightning bolt now works again after a 10 minute fix.Thank you! Wont take pictures with flash - ee25d4ed-a4c0-4894-a734-0022c4fb7446.jpg
Posted on Jan 08, 2014
    Problem Solver:
  • 3 Answers
This is not a battery issue.I have the same problem - sometimes the flash works and sometimes it doesn't. I have tried freshly charged NiMH, new alkalines, and even new Energizer lithium batteries (very high power and long life, but not rechargeable), but it makes no difference. I suspect a problem with electrical contacts inside the camera.
I think this is a design defect of some sort but I have not been able to get any replies from Canon. If I find out anything I'll try to remember to post here.
Posted on May 17, 2010
  • mwf001 Nov 23, 2010
    Me too. Also I get messages to replace the batteries about every other day. I even replaced the CR120 battery. Same problem. I notice that the door to the battery/memory card section doesn't close properly. This probably screws up the electrical connections and cause all the problems. (Only a guess by 20 years experience with computers.)
    New Friend:
If your Power Shot wont take a picture with the flash on, turn the dial to P for program and make sure the flash is set to ON or AUTO
Good luck.
Posted on Mar 11, 2011
  • 289 Answers
Check your battery level; try a fresh set. That may do the trick.
Posted on Apr 24, 2009
6ya staff
SOURCE:
Stuck shutter
It doesn't sound like a shutter problem, especially since the G12 doesn't actually have a mechanical shutter. It sounds as though there is either an exposure setting issue when the camera is in Manual mode or one of the other settings that will allow you to take a photo no matter the conditions. If it does the same thing when in full automatic there could be issues with flash or flash compensation or an internal issue. When it happens again, check to see that the camera has not accidently slipped into another mode.
Oct 04, 2014 | Canon G12 Digital Camera
Cannon EOS Rebel XS won't focus
Switch the lens to "M" and focus manually, then take the photo.
iphoto27atyahoodotcom
Jan 10, 2014 | Canon Rebel XS / Eos 1000D Digital Camera...
Sometimes when i'm taking picture my flash wont stop blinking for a few seconds.
The 400D uses flash assisted focusing. In low light conditions the auto focus cannot get a focus lock so it pops the flash a few times so the lens has a chance to focus. You will notice this will go away when in the manual focus mode (the switch on the side of the lens).
The only way around this problem (as people in a photo think the photo has already been taken and looks away when the camera actually takes the picture) is to use a hotshoe mounted TTL Canon Speedlight (430ex or 580ex) which use an infra-red focussing beam.
Sep 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Wont take a picture unless I turn off the flash
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2008/05/simple-fixes-for-cameras-that-wont-take.html
Jun 15, 2009 | Canon PowerShot A710 IS Digital Camera
Wont take a picture with the flash on!! help
Apr 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon 40D LCD Wont come on buSY flashes in view finder
Okay, this is simple. Your camera can take several pictures at one time in a burst. However when you release the shutter button your processor takes a second to actually SAVE the pictures to the card in the camera. One thing than has helped me in my wedding photography business is to buy the fastest speed cards I can find. It significantly reduced my "busy" time.
Nov 30, 2008 | Canon EOS 40D Digital Camera
Lens Cover Not Opening, Flash Only Occasionally working
my did the same thing.. until I got rid of my recharable batteries and got the ones for electronics
Apr 13, 2008 | Canon PowerShot A75 Digital Camera
Flash stop working Canon A620
Mar 17, 2008 | Canon PowerShot A620 Digital Camera
The flash keeps flashing
hi sneakers
the camera is firing the flash to help it auto focus,the only way to stop it find an area of the picture that has more light/contrast or switch to manual focusing.
regards
ian
Dec 27, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon PowerShot A720 IS Digital Camera Logo
1,486 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
