Gateway MX6956 Notebook Logo
j
jack morrison Posted on Oct 15, 2013
Will not power on
New charger battery only get 4 red flashes help needed
Rik Dollekamp
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Oct 15, 2013
Rik Dollekamp
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
3708
Points
31
When you connect the power, does the charge light lit up? this would tell you the power is transmitted to the battery, wich would mean your DC-jack (where the power goes in) is fine, and the problem might be fixed by:
  1. removing the battery,
  2. remove the power,
  3. hold powerbutton for 20 secs,
  4. re-insert power jack(not battery)
  5. press power on button.
If that didnt work, try the following to determine the DC-jack is the problem:
  1. remove battery
  2. insert power into dc-jack
  3. gently press the power plug into various directions while constantly pressing and releasing the power button.
  4. at some point the laptop should respond by turning on, meaning that you have a faulty dc-jack, which needs re-soldering or even relacement by soldering to repair.
Maybe you also notice that the power connector is very loose in the dc-jack, this might tell you that the dc-jack is the problem..
hope it helps..
1helpful
It's a older model ..Jet 3 power chair / pride manufactured! Hadnt been used in a year and bought a new power cord ...does it need to be charged for 14 hrs to operate...the batteries were replaced 2 yrs...
If the batteries were dead for two years it probably will need new ones. The plates get a coating on them making them useless. This is probably why the charger keeps flashing..
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
2helpful
3answers
What does the flashing red light mean?!?
The flashing red probably means that the charger is working correctly and is indeed charging the batteries. The light should turn green when charging is complete after anything from 1 to 16 hours depending on how this charger works.
Do the following test: Fit the charger with your batteries and connect it to the mains. After 1 hour check if there is a detectable temperature rise in the batteries. You can do this without interrupting the charge cycle by touching the cells with the back of your fingers. If the temperature is still low, let it continue for another 15 hours or so, checking every now & then for any temperature increase. Should the temperature rise more than a few degrees, then stop the charging by removing the charger from the mains. Should the red lamp remain flashing after 16 hours, then I suspect you to have a defective charger.
8helpful
2answers
My Hoveround MPV5 batteries will not charge, do you think it is a battery problem or a charger problem?
If you plug the charger into the wall, turn on the power switch and the light comes on, the charger should be working properly. Here is a way to test it-
Attach the charger that came with the power chair to the power chair controller firmly and turn the power chair on, while the charger is running. What should happen:the lights on the controller will scroll back and forth. If this does NOT happen and you can confirm the charger is turned on, the charger handle is fully seated inside the controller receptacle and the wall outlet has power, then the charger may have a problem and needs to be replaced.
If the charger is OK, then there may be a problem with the batteries. Here are some sypmtoms:
1-You connect the charger but the light on the charger never goes red, it just stays green.
2-You connect the charger but the light goes from red to green VERY fast.
3-The charger light goes from red to green but when you disconnect the charger and press the power button on the controller, you only have one flashing red light, or the batteries drain within just a few minutes of use.
4-The power chair has been stored or sitting idle for several months.
5- The power chair has been connected to the charger 24-7 for several months.
Any of the above examples indicates that the batteries are oxidized or damaged and will most likely need to be replaced. The MPV5 takes two, U1 12 volt 33 amp batteries which can be purchased at any battery warehouse store like Interstate Batteries or Batteries Plus.
5helpful
2answers
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
20helpful
4answers
Battery won't charge on casio ex-z77 exilim
It's a known Fault with the NP-20 battery don't order one and pay for it, ring or e-mail casio customer service they should send you one out for free!! When you receive the new one don't let it die, make sure and keep it partially charged at all time or the charger won't recognize it. Really casio should recall this battery but for some reason they insist on replacing faulty batteries with more faulty batteries!??!
Mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
