SOURCE: transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
SOURCE: tranmitting
one of the units may have a bad mic element. Can you hear the speaker unmute when the radio is keyed?
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
SOURCE: how do i charge the cobra microtalk walk talkies?
Hello there
first i would check the charger to make sure that it is operating properly
next i would check the batteries i know that they are rechargeable but these batteries have a life time too and they will eventually die so you may want to get new batteries. make sure that they are what the manufacture recommends ok
best regards mike
SOURCE: One of my Cobra Microtalk radios is stuck on RX.
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
