I am having a real headache trying to fix this problem im having with this bt250v jabra bluetooth headset to work on my ps3, now ive registered it as normal on my ps3 under accessories, now i cant get to work on the game which is graw 2 no sound nothing i can hear other players through my tv but nothing through his headset ive just bought it too. please can someone help me with this ?
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
I had the same problem, my motorola h375 bluetooth wouldn't pair with my ps3. It was always stuck in scanning. Then I realized that perhaps it's because my bluetooth was already paired with my iphone. I then turned off the the bluetooth setting in my iphone and went back to the ps3 accessories, bluetooth device, registering bluetooth and scanning and it had seemed to work. It scanned my motorola bluetooth and selected it for input and output device. I pressed o.k, back out of that and went to voice inhancement to adjust the mic strength and pitch of my voice. And it everything worked well. I hope this helps. If it doesn't work try using a $29.99 plantronics bluetooth headset from future shop. It's a generic brand that's also sold at eb games store alongside the ps3 bluetooth headset.
While scanning for my blue tooth the PlayStation is taking ages. How do i fix this problem? Why wont my PlayStation find the blue tooth?
I have just bought a Bluespoon AX2 blue tooth headset. I have followed all instructions and paired it up. But when I am playing Resistance I can only hear the other gamers talking, but can't talk via the blue tooth device myself. I hope someone can help as it is very frustrating and I only have a few days to return it if faulty. Many thanks.
i only jus bought it but i cant even register it on me ps3 - i go under accesories and all but wen it says scan it takes for ages
PL z HELp
takes forever to find bluetooth while scanning
Mine doesn't even finish scanning! Someone please help me...
